turbo querie
ajm-e30
am i able to use my exsisting exhaust manifold for a turbo conv, its an m20 by the way......also can i use a turbo of an cossie??
cheers in advance
adam
cheers in advance
adam
CHRISP
- Boost Junkie
march109
Agree but from what I know yes and yes, although you will need to modify your exhaust manifold to direct gases to the turbo rather than staight out so is probaby not the best or easiest solution.CHRISP wrote:The best man to talk to is Ant of a-tech
as for the cossie turbo, depends if it has the characteristics your looking for in a turbo, but there is no reason why not, think these are usually garrett T3's but someone like spadge is the cossie expert.
Ant knows all about BMW FI though.
gcorky
- Boost Junkie
gcorky
- Boost Junkie
i think you may refer to flipping /modding the m20 manifold...and then create a t3 adapter?possible but bit of grinding/porting flange workmarch109 wrote:Agree but from what I know yes and yes, although you will need to modify your exhaust manifold to direct gases to the turbo rather than staight out so is probaby not the best or easiest solution.CHRISP wrote:The best man to talk to is Ant of a-tech
ajm-e30
just at the idea's stage at the moment, dont want big power just useable power for now, i no theres alot more to it than just a few bits and peices so want some different veiws from u lot
gcorky
- Boost Junkie
ajm-e30 wrote:just at the idea's stage at the moment, dont want big power just useable power for now, i no theres alot more to it than just a few bits and peices so want some different veiws from u lot
this is the setup you describe.give blingsta a shout as hes got it fitted,see what you think.
ajm-e30
so basically ill need to get the manifold ported to suit the turbo?? wots the best comp ratio to aim for??
gcorky
- Boost Junkie
ajm-e30
that would be very helpfull, thanks
gcorky
- Boost Junkie
ajm-e30
have u got a pic of the adapter on its own??
gcorky
- Boost Junkie
ajm-e30
nice one, ill look in to it on the weekend now, cheers for ur help
blingsta
- Boost Junkie
Hello mate, just picked up on this thread.... ive got the standard m20 manifold thats been flipped and re-ported with the t3 adaptor (pics above).. currently running a t3 garret from a cossie.... this set up has been very effective for me and im well happy... ive got loadsa pics of my turbo build process if you want to take a look...
gcorky
- Boost Junkie
blingsta
- Boost Junkie
Hello matey, yep, thanx for asking... just bolted on slightly bigger turbo and waiting till thursday to get it re-mapped, on 10.5psi and its mad.... but pinking on boost..
.. hows yours coming along?
gcorky
- Boost Junkie
blingsta wrote:Hello matey, yep, thanx for asking... just bolted on slightly bigger turbo and waiting till thursday to get it re-mapped, on 10.5psi and its mad.... but pinking on boost.... hows yours coming along?
still offroad,debating now on pulling engine out and a freshen up...
got some nice bits!!but ive got a couple of other cars in bits ,mines last on list...hopefully by summer-ISH ill be terrorising the n.e roads...wwoooooaaahhhhhhh..
glad yours is coming along,after your earlier problems,
Turbo-Brown
- Boost Junkie
Pinking on boost? That's not good!
You have the power, MS compells you!
blingsta
- Boost Junkie
Turbo-Brown wrote:Pinking on boost? That's not good!
drives faultless otherwise, and sometimes cant help but put my foot down..... Thursday is the day tho..... all worries should be over...
blingsta
- Boost Junkie
gcorky wrote:blingsta wrote:Hello matey, yep, thanx for asking... just bolted on slightly bigger turbo and waiting till thursday to get it re-mapped, on 10.5psi and its mad.... but pinking on boost.... hows yours coming along?
glad yours is coming along,after your earlier problems,heads-2.7s etc,your nearly there though by the sounds...bet your using a bit of fuel these days
worth it though eh m8
off boost.... im doing 140miles for £20 i think thats great, was doing 100 miles for same amount with no turbo and no m/s.. ???
gcorky
- Boost Junkie
blingsta
- Boost Junkie
cheers pal... will post up results of R/R after its been mapped on Thursday.. im hoping no lower than 230bhp this time round !!! and if it doesnt,
march109
would love to take a lookblingsta wrote:Hello mate, just picked up on this thread.... ive got the standard m20 manifold thats been flipped and re-ported with the t3 adaptor (pics above).. currently running a t3 garret from a cossie.... this set up has been very effective for me and im well happy... ive got loadsa pics of my turbo build process if you want to take a look...
blingsta
- Boost Junkie
no probs matey, just send me your e-mail addy....
ajm-e30
got a link for the pics blingsta??
blingsta
- Boost Junkie
sorry dude, pm me your e-mail addy and i will send them to ya...
[/img]
