pipeing it all up
appletree
Post Mon Jan 08, 2007 10:48 pm
just looking at were the pipe from my cam cover will need to go on the super charer set up .(running, filter>TB>SC>IC>manifold>engine) i take it it should have just atmospheric pressure?? can i use a mini K&N breather??
also what do i do about the Idal control valve?? does this just go after the TB and before the charger (thais space maybe in a small vacum at idal)??
any help from you guy would be usefull. presume its the same problem on a turbo build?
cheers, matt
gcorky
Boost Junkie
Post Mon Jan 08, 2007 10:53 pm
i use a catch tank from cam cover vent..but some do just put a filter on as you suggested.....most ms users on here dont bother with icv.what management are you using?
525 sport
appletree
Post Mon Jan 08, 2007 11:06 pm
not sure at the moment looking at both emerald amd MS Ms would have the soppurt of thr furom and ant though.
so do i scrap the whole thing and block it off??
gcorky
Boost Junkie
Post Mon Jan 08, 2007 11:10 pm
if your getting at your utilizing the original throttle bellows pipe then yes bung it or use the hole for ms air temp sensor.
what boost will your charger produce?
525 sport
appletree
Post Mon Jan 08, 2007 11:20 pm
hopefully around 7psi but it is rated up to 10PSI
7PSI semes to make around 200bhp on standard ECU or thats what downing atlanta get running a bit bigger charger on the Z3 m44. :)
how would a plum in a catch tank fot the cam cover breather??
gcorky
Boost Junkie
Post Mon Jan 08, 2007 11:26 pm
plug the other end at tb...then just bring a pipe from cover into tank...i got a square alloy one off ebay.
525 sport
appletree
Post Mon Jan 08, 2007 11:30 pm
so does the tank empty in to the inlet tract?? way have a tank??
does the pipe need to be under vacum??
Turbo-Brown
Boost Junkie
Post Tue Jan 09, 2007 8:14 am
I just put a filter on the pipe, although it's beginning to make a mess now with oil slowly dribbling down the head and block underneath it.
I regret not making provision for an IACV to be honest, I don't like my engine running at 450ish rpm when it's cold, can't do it much good!
jkarran
Post Tue Jan 09, 2007 1:49 pm
MS air temp sender will need to go after the intercooling, not before the SC.
You could keep the AICV as a bypass on the throttle body (as it is now?) if your managment system will drive it.
Catch tank can be arranged to drain back to the sump if you can be bothered getting a return point welded in or just emptied occasionally, it shouldn't get a lot of oil in it anyway.
There are some small advntages to running the crankcase at reduced pressure, you could maybe arrange something like the brake servo has with a check valve? You could do that in conjunction with a catch tank anyway as most have breather ports.
jk
