Combined oil cooler radiator.
gooner1
- Out humping Reindeer
Can the cooler from the above be separated from the radiator,its from a m535i if that helps at all.
jmc330i
M535i has a separate oil cooler and rad doesnt it?
Unless you mean the auto version which has the rad with transmission oil cooler. If its anything like my M20 auto rad, I dont think they can be separated.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
gooner1
Thanks mate, yes it was from an auto.
ed325i
If you dont want the oil cooler just get a manual rad core fitted or just block the pipe holes off.
jmc330i
Thats what Ive done on my M20 auto rad.ed325i wrote:or just block the pipe holes off.
James
'91 325i Sport
'91 325i Sport
No need even to block them off.
mattG
can the auto rad oil-cooler part be used to cool the engine oil in a manual car so as to get rid of the oil cooler?
jmc330i
I only did to make it look tidy. I got the rad new and it had rubber caps over the inlets, so I just fixed them in place.Brianmoooore wrote:No need even to block them off.
Not sure about using it for the engine oil cooling, not sure what air flow its gets and how effective it would be.
James
'91 325i Sport
'91 325i Sport
