Turbo price?.
gooner1
- Out humping Reindeer
Seen a fair few posts asking the above for a 325i but as yet havent seen an answer.Realize its largeley dependent on how much you pay for the actual turbo itself but a rough figure anyone.Just curious
e30_Turbo
- Boost Junkie
Theres quite a few to choose from but based on Fuzzy's and Dimmys, new garrets were around £1k.
Obviously used is much cheaper but no garuntee's. For first attempt, stage 1 etc I'd suggest a used one, then upgrade when everything else is sorted out.
A big T3 will surfice for low boost on a stock C/R or over a Bar with a dropped C/R.
T4 and bigger if you want big boost on stock C/R but there are limits.
HTH, Mark
HTH, Mark
maxfield
the price really dpends on hoew much power u want
chrisr29
Costs so far:
2nd hand manifold and turbo (off ebay) - £250.00 (tho suspect turbo needs overhaul).
Intercooler (new off ebay) - £105.00
Pluming for above (new) - £220.00
Uprated head bolts - £65.00
....can see this getting pricey...oh well, would only spend it on beer otherwise!
gooner1
OK,say 300bhp.
gooner1
Thanks all, thats given me a roughish idea.Mark mine is the early 86 engine,is that a good or bad thing as far as turboing i s concerned
maxfield
its not the best thing as its higher compression but still can be turboed. i think trhe compression is 9:7:1 and the later engines are 8:8:1 or something like that
gooner1
Also there seems to be a difference of opinion as to whether the early ones can be chipped or not.
Any definitave answers on this anyone?
Turbo-Brown
- Boost Junkie
You won't need to worry about chipping if you're doing the conversion properly and fitting an aftermarket mappable ECU
gooner1
Seem to remember someone talking about using a turbo from a train.Is that feasible,i work for Network rail
fuzzy
i got no change from a grand for my brand new,non exchange stage 2 garrett t34 with cut back blades and a 360 degree bearing but that was with extra bits and bobs such as a couple of new samco hoses etc.the turbo on its own was just under £800.i would never buy a second hand turbo as my experiences have found them to be a false economy resulting in paying out for replacements within months.
