supercharged
wells696
any1 used one of them electric superchargers are they any good for the money saw 1 for £100 and they said 15bhp gain are thay talkin s#*t
got my white coupe for sale
DaveD
- E30Zone Wiki Specialist
there has been a few threads on these in both the zone and e30tech all of which said 'load of crap'
cass1_5503
there was a write up in one of the moded mags they tested one on a mr2 and it actually lost power so they are a pile of s**t
fuzzy
is that the one were its basically a little pc type cooling fan that goes into your air intake?never actually seen or used one but general consensus is as above
wells696
http://cgi.ebay.co.uk/electric-Supercha ... dZViewItem
This is the link to the item i was looking at
maxfield
no no no
been discussed plenty of times would lose power was the conclusion.
wells696
thanks alot will save my money any ideas wat i can spend £100 on to make it betta i got a 320 with 325inlet and tb k&n panel filter and chiped
fuzzy
i dont believe in these things personally but how many of the people who slate them have actually used or tested one and formed a conclusive result rather than jumping on a hearsay bandwagon?but like i say i wouldnt spend my money on onemaxfield wrote:no no no
yamoda
If you look at the cfm of even very powerful small electric fans, you can work out that you would need at least 100 of them to make even a small difference and an alternator the size of Essex to power them.fuzzy wrote:i dont believe in these things personally but how many of the people who slate them have actually used or tested one and formed a conclusive result rather than jumping on a hearsay bandwagon?but like i say i wouldnt spend my money on onemaxfield wrote:no no no
bigkev
cass1_5503
plus the fan is a restriction on the airflowIf you look at the cfm of even very powerful small electric fans, you can work out that you would need at least 100 of them to make even a small difference and an alternator the size of Essex to power them.
fuzzy
if a fan is a restriction on airflow why have 2 of them on the radiator?cass1_5503 wrote:plus the fan is a restriction on the airflowIf you look at the cfm of even very powerful small electric fans, you can work out that you would need at least 100 of them to make even a small difference and an alternator the size of Essex to power them.
johnl320
Too cool the radiator down when they're is no air flowing through it. ie. heavy traffic! What sort of a question/ statement is that ?fuzzy wrote:if a fan is a restriction on airflow why have 2 of them on the radiator?cass1_5503 wrote:plus the fan is a restriction on the airflowIf you look at the cfm of even very powerful small electric fans, you can work out that you would need at least 100 of them to make even a small difference and an alternator the size of Essex to power them.
john
