FAO ian332i sport or anyone else with the answers plz!
orr
FAO ian332i sport .I have been told your the man to speak to about wiring . I am doing e30 m3 s14 engine swap, putting in a 95 e36 m3 s50 3L I have got the engine harness plugs off both looms to make a connecting harness from the new engine to the car. Can you give me a list or tell me which pin does what, and how to connect them together.
Will everything still work as normal on the instrument cluster after the wiring has been done?
Thanks a lot!
Orr
Thanks a lot!
Orr
Ian is the man to speak to, but at the moment he's on the other side of the world!
buster
here are the pin outs you need.
x20...................c101
25 BL................1 BU Alternator d+
2 GN/GE...........2 BU/BK oil level sensor static
7 GN.................3 GN enable signal from ews 2 pin 4 to motronic pin 66
12 BR/VI...........4 BR/VI coolant temp sender to instrument clust,c1 pin26
23 BR/GN..........5 BK/BR oil pressure switch to inst cluster c1 pin 18
22 GN/WS.........6 GN/YL Live in run&start from ign swith
21 GN...............7 GN start sig to motronic pin 56
24 WS/SW.........8 YL/WT Fuel output- motronic pin 46 to inst clust c1 pin11
20 SW...............9 BK enginespeed o/p frm motronic pin47 to c1 pin7(tach)
1 BL..................10 VI/GN oil level sensor dynamic
19 WS/GN..........11 diagnostic connector (service reset)
........................12 ------ not used
13 GN/VI...........13 VI/RD fuel pump relay to fusebox (fuse 11)
14 SW/WS.........14 BU/YL road speed signal to motronic pin42
15 SW/GN..........15 BK/GN starter unloader relays & inst cluster c1 pin 1
.........................16------not used
17 WS/VI...........17 WS/VI diagnostic connector pin 20 (tx) to ews 2.pin 2
18 SW/GE..........18 BK/YL starter sigfrom ign switch to solenoid,via ews2
9 BR/RT.............19 BR/YL oil temp sender to inst clustr c6 pin 2 (e30m3)
3 splice 6821 RT/WS..20 RD/YL main relay term 87 to abs pin 10
ian332isport
Hi Sam,CiLK_WuRM wrote:where is he?
I'm back now (arrived home yesterday morning), but was over in your part of the world driving around New Zealand in a camper van for 3 weeks (1 week on the North island and 2 on the South). I also popped over to the West island (Australia
Orr,
I'm guessing Andy (Buster) has provided the pin connections for the 3.2 Evo engine. If this is the case, then it may not be 100% accurate.
If you can let me know the wire colours and pin numbers on the E36 engine connector, and the same for the E30 body connector, I can do you an accurate connection chart.
Cheers,
Ian.
orr
Thanks for all your help lads!
You will be charging me for all this info next!
Orr
Orr
orr
Hi Ian! Here goes...
E30 M3 514 20 pin plug
1 Blue
2 Brown & Orange with a small resistor that connects to a brown wire and goes to pin 10! Don't know what this is for!
3 Blank
4 Brown & white
5 Brown & green
6 Fat green and yellow with thin yellow and blue... 2 wires
7 Fat green & thin green.. 2 wires
8 White
9 Black
10 Brown and it connects to pin number 2 with a small resistor
11 Blue & white
12 Blank
13 Green & purple
14 Blank
15 Green & black
16 Black 7 white
17 Blank
18 Black & yellow
19 Brown & purple
20 Red & Yellow
E36 M3 3Lt 25 pin plug
1,2,3,4,5,6 all blank
7 Fat green
8 Blank
9 Red & brown
10 Yellow & blue
11 Brown & yellow
12 Brown & purple
13 Green & purple
14 Black & white
15 Black & green
16 Yellow & white
17 White & purple
18 Fat black & yellow
19 White & green
20 Black
21 Fat green
22 Green & white
23 Green & brown
24 Black & white
25 Blue
Thanks Ian, hope you can help from this info
Orr
1 Blue
3 Blank
4 Brown & white
5 Brown & green
8 White
9 Black
11 Blue & white
12 Blank
13 Green & purple
14 Blank
15 Green & black
16 Black 7 white
17 Blank
18 Black & yellow
19 Brown & purple
20 Red & Yellow
7 Fat green
8 Blank
9 Red & brown
10 Yellow & blue
11 Brown & yellow
12 Brown & purple
13 Green & purple
14 Black & white
15 Black & green
16 Yellow & white
17 White & purple
19 White & green
20 Black
21 Fat green
22 Green & white
23 Green & brown
24 Black & white
25 Blue
Orr
ian332isport
Orr,
Thanks for the pin details, but can you confirm a couple of things.
1. What year is the E30 M3, and are those pin details from the car side of the 20 pin connector ? It looks like the engine side going by the colours, but I really need the car side which are a bit different.
For the record, the resistor across pin 2 & 10 is to trick the check control unit into thinking the oil level is okay. The M3 never had an oil level sensor fitted, so the resistor was used to avoid a constant oil level error on the check control unit.
2. What year is the E36 M3 ?
Cheers,
Ian.
Cheers,
Ian.
orr
Hi Ian
It is a 1990 M3 and this is the car side! The other ones were the engine but the E36 ones were for the body!
I have just taken my timing case off to renew the front crank seal and the right hand side slide rail that the chain runs in between is lose because the bolts that hold it in place are broken! Has enyone else had this problem and what do you think has caused it and will it have caused the chain to move? Not happy!!
1 Blue
2 Blue/black
3 Blank
4 Brown/purple
5 Black/brown
6 Green/yellow
7 Green
8 Yellow/white
9 Black
10 Purple/green
11 White/blue
12 Blank
13 Red/purple
14 Blue/yellow
15 BLack/green
16 White/black
17 Blank
18 Black/yellow
19 Brown/white-brown not sure which colour
20 Red/yellow
alos does anybody know of a webite that can tell me the tourque settings for the nut and bolts on the engine?
Cheers lads
Orr
1 Blue
2 Blue/black
3 Blank
4 Brown/purple
5 Black/brown
6 Green/yellow
7 Green
8 Yellow/white
9 Black
10 Purple/green
11 White/blue
12 Blank
13 Red/purple
14 Blue/yellow
15 BLack/green
16 White/black
17 Blank
18 Black/yellow
20 Red/yellow
Cheers lads
Orr
I did one a few weeks ago mate, heres the thread if it helps
ian332isport
Orr,
I've got your wiring charts ready, but they are in Excel format. If you can PM me an email address, I'll send them over.
Cheers,
Ian.
Cheers,
Ian.
orr
Thanks dan. ian my sister has sent you my email address not very good on the computer yet, just been looking at the spec of your car looks great .Do you think i will mess up the handling of my M3 a bit wooried i will not like it when its done. The car is like new as i have it in the garage all the time, but i have had it 8 years now and am bored with the performance. 220bhp. Heared a lot of bottom end problems with the E36 M3. Went to renew the front crankseal , on the E36 while it is still out of the car and when i removed the front timming cover the right hand side timming chain guide rail was loose, the bolts that hold it in place had sheared. Ever heard of this happening?
Thanks for all your help mate.
ian332isport
Orr,orr wrote:Thanks dan. ian my sister has sent you my email address not very good on the computer yet, just been looking at the spec of your car looks great .Do you think i will mess up the handling of my M3 a bit wooried i will not like it when its done. The car is like new as i have it in the garage all the time, but i have had it 8 years now and am bored with the performance. 220bhp. Heared a lot of bottom end problems with the E36 M3. Went to renew the front crankseal , on the E36 while it is still out of the car and when i removed the front timming cover the right hand side timming chain guide rail was loose, the bolts that hold it in place had sheared. Ever heard of this happening?![]()
No, I don't think it will mess up the handling. I helped another guy with a similar conversion (using the 3.2 Evo engine) in an E30 M3, and he's not noticed any difference. If it was a competition or track day car, you may notice a small difference on the limit, but on the road you won't tell the difference at all.
I have heard the odd story about bottom end problems, but that was aimed more at the 3.2 Evo than the 3.0L engines. Even then, it's not that common and can be stopped from happening by fitting ARP rod bolts.
Can't say I've ever heard of problems with the timing chain or guides. Apart from the rod bolt issue mentioned above, and Vanos on the 3.2 Evo engine, they don't have any inherent problems to speak of.
Ian.
orr
Hi Ian
Cheers for the wiring info!
I will go and see if i can understand all this stuff! Not very good with the wiring....
Anyway you should be out in your BM scairng off them Scooby doos!!!
Thanks again
Orr
Thanks again
Orr
