whos run NOS on m20 lump ? before ?,
any problems, things to look out for , before fitting or weak pionts ?
I ve gots Fuzzy's wizard kit, 6 fogger system , so will run it as a 50 at first and gradually up it to 100 or 125 jets dependant on detonation etc , will std head bolts & gasket take this ?
i can drill and tap each runner but before i do , do 6 pots like the foggers as close up to the intake valve as poss , or further back ?
As i ve already got Maxiumzer controller and retard box , spare , so i was thinking at about 3 deg at first then may be 4 to 6 for 125 jets , unless any knows diff?
its goting on to a 2.7 eta lump with 320 head with 325 valves ported out etc std 325 cam ,
i'm not sure what to reduce the fuel pressure down too first ?,
tell me what u've tried and what works and what does nt ,
cheers
