m-dtech
- Unapproved Trader caution
Post
Mon Oct 16, 2006 7:29 pm
Right ive lost my baby to some thieving bastard so im going to do what i want to do to an E30.......... (apart from fit an immobiliser)
M50 2.5 / 2.8
So all you m50 boys let me know how u did it and what you used.
andyborris
Post
Mon Oct 16, 2006 8:50 pm
Might want to talk to Ant too, (long story short) my Tourer has a M50 and uses the original BMW brake servo and he's the guy who spotted it. And it's no good asking me about it, I didn't do the conversion, I just brought it of Ebay 'cos I fancied a Tourer!
m-dtech
Post
Mon Oct 16, 2006 8:52 pm
can you post up pictures ??? m
jmc330i
Post
Mon Oct 16, 2006 8:57 pm
andyborris wrote:my Tourer has a M50 and uses the original BMW brake servo
I think this is possible if the angle of the engine tilt is altered.
James
'91 325i Sport
'93 318i touring 16v
320Touring
Post
Mon Oct 16, 2006 8:59 pm
M50 How TO Guide
1.Buy e30 325i
2. Drive the m20 and realise that the m20 is a great engine, and leave it in there
3. Use all the spare time you have to drive and do other things!
the end
m-dtech
Post
Mon Oct 16, 2006 9:07 pm
320Touring wrote:M50 How TO Guide
1.Buy e30 325i
the end
stop spamming this is real talk about real engines.
Post
Mon Oct 16, 2006 10:12 pm
Have you got any pics of this mate?
You might want to add them to the M50 developments thread
Post
Tue Oct 17, 2006 12:55 am
So has mine. I moved the whole servo/cylinder closer to the LH side of the bulkhead and used a longer pull rod.
Only possible with RHD cars of course.
Tom944
Post
Tue Oct 17, 2006 10:15 am
I don't know if you want my modlist for the m50 engine since I've got a LHD car. If you do, let me know here.
E30 M50B25 racer soon-to-be E30 S50B30 racer
andyborris
Post
Tue Oct 17, 2006 10:24 am
DanThe wrote:andyborris wrote:my Tourer has a M50 and uses the original BMW brake servo
I can get some pics, but I have no idea how this was done! Ant did some work on the car and he mentioned it.
I should see him in a few weeks time and I'll get him to explain it fully, either to me or onto the forum.
If I place the pics here and they're worth keeping, maybe a mod can put them into the correct thread?
Post
Tue Oct 17, 2006 5:00 pm
There is a link to the "M50 developments" thread in my first reply above
monkey
Post
Tue Oct 17, 2006 8:28 pm
i to am interesed in fitting an m50 i have spent days looking in to it and i can't find anything on wiring is this because its an easy job or just that no one wants to let on ? please help , the engine and loom i will probably use is from an e34 2.5 as i can get one real cheap, is there any avantage to using a non vanos engine / will this make it easyer . thanks matt
Post
Tue Oct 17, 2006 9:39 pm
There have been pages and pages posted on here regards the wiring, which is fairly easy, especially if you use an E34 loom. Basically change the big E34 plug for an E30 one and find somewhere to park the ECU.
The only advantage of using a non vanos engine is that it will probably cheaper. For the advantage of using Vanos, just drive one, then you'll know!
monkey
Post
Tue Oct 17, 2006 9:44 pm
thanks , sounds simple best give it a go then
EOS
Post
Wed Oct 18, 2006 7:10 am
Hi im on my 2nd M50 conversion now, on the first one i used the golf servo cause thats what i thought you had to use, but on my second one i used E36 alloy mounts and E34 rubbers and the engine dropped in with the standard E30 servo. It just touches the ribs on the inlet manifold. Can only post pics at the weekend if you want some as photobucket etc is banned at my work
m-dtech
Post
Wed Oct 18, 2006 8:38 pm
Can anyone give a summary of parts needed ??
mike
Post
Wed Oct 18, 2006 9:06 pm
Depends on what E30 you start with, whether the engine comes from an E34/E39/E36 etc, what gearbox you use, what exhaust you want to use and so on
There is no definitive summary
Post
Wed Oct 18, 2006 9:09 pm
m-dtech wrote:Can anyone give a summary of parts needed ??
mike
There's no one solution except for E36 alloy engine mount arms and E34 sump and oil pick up.
Use the forum search function, or trawl through the "engine swaps/forced induction" forum.
All you need to know is there, several times over.
m-dtech
Post
Wed Oct 18, 2006 9:12 pm
1994 E34 Engine & Loom
E36 Gearbox
E36 318i Gear Linkage
E36 Engine Mounts
E34 Engine Rubber Mounts
Mk2 Golf Servo (i know its not needed but i dont want anything rubbing on the engine)
E30 325i Radiator
M3 Prop or E36 318/325 Combi.
Cooling Fans Of Some sort
What Have i missed ??
m
Post
Wed Oct 18, 2006 9:17 pm
Diff - 4th on a M20 box = 5th on an E36 box.
The whole of the exhaust system.
Post
Wed Oct 18, 2006 9:21 pm
If you are going to be searching for an E36 box then find one with the smaller output flange, that way you can use an E30 320 prop and save having to buy an M3 one.
Not sure of the 318 gear linkage, but I 'know' that a 325 one works
m-dtech
Post
Wed Oct 18, 2006 9:27 pm
Brianmoooore wrote:Diff - 4th on a M20 box = 5th on an E36 box.
what would the diff from a 525e do to the final drive ?
ratio of 2.93 iirc ?
Post
Wed Oct 18, 2006 9:37 pm
There are 2 sizes on the E28, the larger one wont fit
Ask Andy325
bigdek
Post
Wed Oct 18, 2006 9:42 pm
m-dtech wrote:Brianmoooore wrote:Diff - 4th on a M20 box = 5th on an E36 box.
i know a man who had one of these but he gave it away
Post
Wed Oct 18, 2006 9:46 pm
525e diff is what I've used.
The equivalence factor is 0-81.
2.93 will be the equivalent of 2.93/0.81 = 3.62 with the original E30 box.
m-dtech
Post
bigdek wrote:m-dtech wrote:Brianmoooore wrote:Diff - 4th on a M20 box = 5th on an E36 box.
i have another
m-dtech
Post
Wed Oct 18, 2006 9:48 pm
Brianmoooore wrote:m-dtech wrote:Brianmoooore wrote:Diff - 4th on a M20 box = 5th on an E36 box.
with a bit of work could the 2.93 e28 diff be re-built into lsd form ??
bigdek
