M30 engine oil leak
Rich25i
Post Thu Oct 12, 2006 1:20 pm
Hey not sure if this is the right place but...
I have found a 535i manual to use as my doner car for a possible engine conversion but it has an oil leak. its at the front and looks like its coming from the sum/block join. as the engine is coming out i will change it but could this be something else to worry about.
I cant see exactly where its coming from.
Thanks in advance
Rich
ed325i
Post Thu Oct 12, 2006 7:11 pm
Could be the front crank seal.
Rich25i
Post Thu Oct 12, 2006 7:40 pm
Ahh thank you. I did not think of that will check tomorrow. is it a easy fix?
ed325i
Post Thu Oct 12, 2006 8:18 pm
is it a easy fix?
Remove the crankshaft pulley and vibration damper, Prise the old seal out of the cover, Clean it up, coat the new seal in engine oil or grease, then using a socket or bit of pipe with an outside diameter of the seal drive the new seal into place and then replace the damper and pulley.
gareth
Post Thu Oct 12, 2006 10:05 pm
it might be worth pulling the sump for a cleanout and checkover anyway so the sump gasket and both crank seals could be done then. afaik there isn't anything else further up on a M30 that can leak oil other than the head gasket. this would be obvious though.
Rich25i
Post Fri Oct 13, 2006 3:37 am
thanks alot guys
ant2
Post Fri Oct 13, 2006 3:44 am
its the front cover bolts, mine leakes from their, stick some gasket sealent on all the bolts includind the front pully sensot bolts
DRIFTBOY
Post Fri Oct 13, 2006 11:12 am
Beware if you are removing the crank pulley nut - it is VERY tight!
An air gun is useful here. I don't have one and ended up cutting mine off!
Rich25i
Post Fri Oct 13, 2006 6:20 pm
thanks guys for your help. i will be driving this car till after xmas when i can get a good shell.
