Avner, good points well made dude but, more oil flow results in lower core temp and increased turbo life.
Take a turbo to bits and splitthe bearing core, then compare water and oil/air coioled units
As for the volvo IC install, I'll take some more pix as I work thorugh the current install, but here's a taster.
the oil cooler must be re-loacted but the rad stays in the stock position, the car pctured runs an Mtech2 kit so I chopped all the lower inner valance away, but you can do it as mine is , you will need an iS lip spoiler though as the IC pokes about 70mm lower than the stock valance does.
HTH
Email FTW
