Wasted Spark Installed
Ant
Retired Team Member
Retired Team Member
Post Tue Sep 05, 2006 6:06 pm
I have spent the last 2 days totally rewiring my MS ECU to run a coilpack, today was the last installment and all went well.
Nice to be rid of the dizzy cap and arm, and finally have full spark control ( nobbled motronic previously ), soft and hard cut limiters, launch and traction control options all tested and working good.
Car starts better, idles smoother and generall more responsive, I will say though that upon removal my dizzy cap was cracked and the rotor arm was in fact in 3 pieces, no idea why but I guess they were due for a change anyways :lol:
For the cost of the new cap n arm, I got a brand new Omega Coilpack and connector so no real extra cost, just lots of time( big thanks to Alex for the pinouts ! )
need to sort out my Tach out pin, no tach @ the mo which is annoying....... little job for tomorrow perhaps.
Pic of the revised setup, might re-jig the HT lead run to tidy it a little but for now, here is the fruits of my labours.
Will add some more boost tomorrow and go and play some more :thumb:
d6dph
Post Tue Sep 05, 2006 6:19 pm
:eek: How do you know where to start dude! Absolute respect from me, i would be lost doing things like that.
Turbo-Brown
Boost Junkie
Post Tue Sep 05, 2006 7:45 pm
Yay! Glad to be of help! :D
Did you increase the plug gap in the end?
They're mega powerful these coils, I'm running a 0.9mm gap on mine :)
fowler
Boost Junkie
Post Tue Sep 05, 2006 8:17 pm
me want one !!!! ant add these to the list for me please cheers Bud
EX A-Tech Workshop bitch !!!
gone but not forgotten
Andy335Touring
Post Tue Sep 05, 2006 9:08 pm
Nice one Ant, I must get around to fitting my cossie V6 coil pack and figuring out the wiring, four pin's, one's got to be postive feed and the others i'd guess are paired negative trigger inputs ?
Post Tue Sep 05, 2006 9:15 pm
What sort of 0-60 time and top speed are you getting out of this delectable beast? Nicely modded :!:
Turbo-Brown
Boost Junkie
Post Tue Sep 05, 2006 9:20 pm
Andy335Touring wrote:Nice one Ant, I must get around to fitting my cossie V6 coil pack and figuring out the wiring, four pin's, one's got to be postive feed and the others i'd guess are paired negative trigger inputs ?
That's it :)
Way I got my pinout was to rig up a sparkplug earth to a battery and an HT lead, power up whichever low tension side pin has the least resistance when read against any one of the other LT pins (you're only reading through one coil if you've got the +ve pin and one other) and then flick an earth across the LT pins and see what the plug does.
You have to be patient as it doesn't give a terribly strong spark, but it does work and gives consistent results!
Then just note down which LT pin does what, rig up to the ECU and tell it what to expect, then ignore what's written on the coilpack for the HT outputs as they'll be different on the V6 :)
Andy335Touring
Post Tue Sep 05, 2006 9:29 pm
Cheers mate :thumb:
buster
Post Tue Sep 05, 2006 9:50 pm
Nice beaver !
Is there a trigger or pick up needed for that then ?
Ant
Retired Team Member
Retired Team Member
Post Tue Sep 05, 2006 9:53 pm
Coilpack is triggered from the std 60-2 wheel and VR sensor Andy, this MS has triple coil drivers internally to run the pack, no external EDIS module is being used.
Cheers for the positives 8) defo gonna re-do the HT leads though, expect an edit tomorrow sometime :lol:
buster
Post Tue Sep 05, 2006 10:01 pm
its clever stuff this mega squirt stuff,even more clever figuring it all out !!
keep up the good work mate :thumb:
tim_s
Post Tue Sep 05, 2006 10:26 pm
nice! did i read that right, you're only using 3 coil drivers to run that ant?
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
Gunni
Post Wed Sep 06, 2006 2:13 am
Well thats needed obviously,
3 outputs, one for each of the coils, each coil has 2 outputs totally in 6 cylenders,
if heԚ´d be able to run 6 outputs having 6 individual coils would be pretty neat,
space consuming but need nonetheless
Gunni
@ 2012 VEMS group buy !!
Turbo-Brown
Boost Junkie
Post Wed Sep 06, 2006 8:18 am
Would be a further pain in the arse to have sequential ignition as you'd need to rig up a Cam Posision Sensor in addition to the Crank Position Sensor.
tim_s
Post Wed Sep 06, 2006 8:53 am
Gunni wrote:Well thats needed obviously,
that's pointing out the obvious gunni! i ask because this setup produced too weak a spark for me. you can run multiple coil drivers from one output, still wasted spark.
Boots_Walker
Post Wed Sep 06, 2006 10:13 am
Ant that is sweet.
have you got a battery in the front there? i always thought that would be a handy spot to mount the coil pack, although you would need some longish leads
i should be installing my EDIS wasted spark in the first week of October, keeps getting pushed back while i fix other little things (oil leaks, clutch etc). finally got an MSII cpu module too :) btw can you send me that N/A m20 spark map? (if you need my email address again let me know)
Morat
Post Wed Sep 06, 2006 12:22 pm
Very nice indeed - removing another known E30 weakspot :)
How much of the original loom is still being used? - and will you be offering this as part of your MS kits?
Still very interested, just trying to sort out the crap running.. which we think is down to a fault in the loom....
Best of luck!
Morat
Ant
Retired Team Member
Retired Team Member
Post Wed Sep 06, 2006 2:34 pm
Yeah, certainly all MS kits will now be built with the provision for wasted, Blingsta's cab is equipped with the exact same ECU and loom as mine, however the two " spare" coil drivers are software disabled for now.
Seems to be advisable to future proof the setups as I go, can be added retrospectivly to all existing MS V3.0 ECU's too, so bonus there :cool:
If I could get numbers for an MS group buy, and get confirmed orede with deposits, we could all save a few Ԛ£Ã”šÃ‚£.
Morat, the only parts left are the coil +'ive feed, the coolant temp wiring and thats about it, the rest of the motronic is still in place, but all dormant, this way the engine bay looms stays stock to look @ :twisted:
dan_emaps
Post Wed Sep 06, 2006 9:04 pm
unfortunately its still going to be some time before i can think about getting my MS, but a group buy would be cool! Ant how much do you reckon it would cost to get this done whilst your doing my MS?
FlappySocks
Post Wed Sep 06, 2006 9:18 pm
I'm interested in a group buy. Depends on the cost really. I'm handy with a soldering iron, so I was going to build it all from scratch to save money. However I can't afford to keep my E30 off the road for too long, so I need to be confident it's all going to work.
Stuart.
Morat
Post Thu Sep 07, 2006 12:57 am
I'd be interested in a group buy for Ant MS kits, not sure when I'd be able to cough up but give me enough warning and I'll start on the bread and water :)
cplagz
Post Thu Sep 07, 2006 5:16 am
Looks great Ant, I'll have to hassle you when I get my MS PCB3.0 installed :)
Gunni
Post Thu Sep 07, 2006 11:58 am
Well is a single driver able to produce enough power for 2 outputs?
A single driver powering a wasted spark would mean
twice fired per rev, each fire has 2 sparks , total 4,
Gunni
Ant
Retired Team Member
Retired Team Member
Post Thu Sep 07, 2006 1:18 pm
the driver does not produce the power, the coil is grounded through the driver FET when signalled by the ECU.
Hooking two coils to sink through one driver would mean the driver is coping with double the current load as Gunni has indicated, with the MS VB921, they are current limiting but the excess duty will be obvious as a lot of heat regardless of the selected dwell interval.
Tim,, you paired yours off then dude ?
@ Gunni, hows that ECU coming along you were wanting to use last we spoke?
Oh, had 1st drive yesterday, smoooooth baby, pleased with this little upgrade :cool:
Gunni
Post Thu Sep 07, 2006 2:36 pm
Well, My friend bought it but one driver was dead, so it was sent to the manf.
and should return soon,
on a side note ; I will be getting one for myself :)
IԚ´m going to run it on a M10 going trough few stages,
Stage 1 :
Wasetd spark, NA config with TPS for load, launch control if I bother,
no afm, MAP sensor will be installed, also wideband sensor and controller for monitoring afr, egt, air pressure and rpmԚ´s. injectors will hopefully be big enough from the get go to run what I need in the final stage although thats not really a concern
I hope to get 125-135hp on a othewise stock 1.8
Stage 2 :
Same as before , only added turbo , a very big one, boost up to 1bar,
Hope to get about 250hp as the back end will be real open
"3 exhaust
Stage 3:
Crazy cams, possibly bigger turbo, boost 2-2.3bar
should make shits of power,
IԚ´m collecting M10Ԛ´s as we speak to have in stock ;)
This is the unit I will be working with
http://www.perfectpower.com/products/xms.asp
Gunni
WillG
Post Thu Sep 07, 2006 5:48 pm
put me down for one ant if you do GB on the MS with 3 drivers, already got some MSD coils
stuartgallafant
Post Thu Sep 07, 2006 11:03 pm
Ant, you are god!!! total respect from me too! i'll be needing to pick your brains!!
tim_s
Post Fri Sep 08, 2006 12:36 am
stuartgallafant wrote:Ant, you are god!!! total respect from me too! i'll be needing to pick your brains!!
you thinking of going MS on the 318is dude?
chu346
Post Fri Sep 08, 2006 7:46 pm
How much would this upgrade cost me?
Andy335Touring
Post Mon Sep 18, 2006 1:38 am
Bump :)
Just wanted to publicly thank Alex for the Emerald ignition driver out puts, nice one mate :thumb:
I've also got the pin outs for the cozzy coil from a chap off one of the Ford forums this evening so i should be able to go dizzyless soon, touch wood !
Oh, and i'd thought i'd share this link i've found, looks like it's fairly cheap ? Coils/AFM's/WBO2's/etc
Audi TT WBO2, same as the ones used as the Inovate kits i think for 61 quid delivered
Brand new cozzy V6 coil pack for just over 50 quid with three year guarantee
http://www.ignitioncoil.co.uk/
Demlotcrew
Post Mon Sep 18, 2006 12:17 pm
Cheers for the link Andy.
Edit, it doesnt seem to be working.
Andrew
E30Mark
Post Mon Sep 18, 2006 1:38 pm
PM for details
Turbo-Brown
Boost Junkie
Post Mon Sep 18, 2006 1:42 pm
He he, no worries!
Don't forget to reap the benefits of bigger plug gaps once you're up and running :cool:
Andy335Touring
Post Mon Sep 18, 2006 9:16 pm
What sort of gap do i need ?
Standard is 0.7mm
Demlotcrew
Post Mon Sep 18, 2006 9:26 pm
Andy use iridium plugs, worked wonders for me.
Andrew
