Scary big turbo for you nutters :)
Morat
Post Fri Jun 16, 2006 3:19 pm
On ebay Here
Just incase anyone can use :)
Morat
maxfield
Post Fri Jun 16, 2006 3:20 pm
8O
e30_Turbo
Boost Junkie
Post Fri Jun 16, 2006 3:34 pm
OY!!
I was keeping a sneaky eye on that one! LOL!
Thats not one to use on less than a M30 really, I doubt it would boost on a 2.5 or 2.7/2.8!
Mines a size smaller (HX40ish) and I don't get boost till 4k!
HTH, Mark
dazleeds
old skool raver
old skool raver
Post Fri Jun 16, 2006 3:35 pm
hmmmm booost at 7k maybe? 8O
www.oldskoolfantasy.co.uk
Geeman
Post Fri Jun 16, 2006 3:54 pm
Mark... you're not serious are you...? Would you be able to fit that under the bonnet with an M30 squeezed in too...?
e30_Turbo
Boost Junkie
Post Fri Jun 16, 2006 4:34 pm
Geeman wrote:Mark... you're not serious are you...? Would you be able to fit that under the bonnet with an M30 squeezed in too...?
Easy!
If you go for the front mount as toby did there is quite a bit of room to use up, mines a mid mount and I have a large turbo fitting quite well in there:
I'd say go for it, but you'd need a bloody strong manifold to mount that fecker tho!
It's gotta be good for 700bhp+ that thing!
You having ideas Giles?
Mark.
Morat
Post Fri Jun 16, 2006 5:01 pm
Jeezus!
I guess we can work out why the guy didn't use it on a Cosworth then. They're only 2 litres aren't they?
WillG
Post Fri Jun 16, 2006 5:20 pm
Its too big for a cosworth and it looks fucked with all that ally oxide inside compressor probly been leaft outside for ages so it will need rebuilding. With a turbo that size VS motor made a 3.6 M5 engine with 1400 hp with no NOS. Those size turbos are only good for drag racing and if your into that your spending so much you wouldnt try to save money using a holset anyway.
fuzzy
He who sleeps with "Gingers"
Post Fri Jun 16, 2006 5:23 pm
a cosworth t4 turbo wouldnt be far behind that,my smaller t34 can run up to 32 psi,but would need serious internal works done to handle 45psi :eek:
e30_Turbo
Boost Junkie
Post Fri Jun 16, 2006 6:15 pm
fuzzy wrote:a cosworth t4 turbo wouldnt be far behind that,my smaller t34 can run up to 32 psi,but would need serious internal works done to handle 45psi :eek:
Dude,
You could fit a T4 inside that HX50, in fact it's poss bigger than a GT40.
It's hard to see from the pic but that thing is a absolute monster!
Came off a 10/15ltr diesel engine but I'd love to see it in action on a m30 tho! :cool:
Turbo-Brown
Boost Junkie
Post Fri Jun 16, 2006 6:22 pm
Don't know why people quote how much pressure a turbo will supply, it's not all that relevant.
It's how much pressure they can give whilst also supplying a given volume of air that paints more of a picture.
WillG
Post Fri Jun 16, 2006 6:53 pm
peppe uses a HX50 on his M20 but the compressor side looks much bigger then his in photo, but its a wierd photo I think the kids leg makes it look bigger then it is, it is still a T4 flange and outlet 4", turbine doesnt look as big with tape measure against it. Robins/ronta VM performance used one on a M20 aswell if you want to see one in action here is the video http://videos.streetfire.net/hottestvid ... 380330.htm and ignore the title, its not 900 hp and its not 3.8 litre
