can anyone tell me exactly what i need in order to convert my 1988 320i into a 325i.
some say straight swap..some say gearbox and diff as well...others say new sensors and front mounted oil pumps please help as desperate to get started a.s.a.p
professional help desperatly needed for 325 conv
telski789
to do a swap you can use the 320i gearbox and diff,but this means you will get more accelaration and less top end,which i like! you could do this until you get a gearbox and diff sorted or keep it like it if you wish . the only thing you have to do is get the oil cooler,this connects to where the oil filter is on the engine so all the gubbins should be there! cooling system is all the same,so you can use your old cooling system. obviously need to change the engine loom and ecu,but this is easy as the loom is seperate from the main loom. hope this helps
Tel
Tel
fowler
- Boost Junkie
hello mate i did thid conversion on my 320i convertible it is easy i have a complete setup if you are interested i will sell the whole lot for £400
that include
engine early nice high compression lump ( Actually makes the 171bhp stated)
gearbox
ecu(chipped )
Afm with cone filter ( Pipercross
altenator
and all assoited bits dodgy spelling.
You also need 325i struts as the 320i ones are smaller in diameter
that about it couple of days done if you want a long day in a day
regards
Ben
that include
gearbox
ecu(chipped )
altenator
regards
Ben
EX A-Tech Workshop bitch !!!
gone but not forgotten
fowler
- Boost Junkie
for got to ad where abouts are you as i don't mind giving you a hand
regards
Ben
regards
Ben
Nelly
- Gumbo
To be honest, all you need is a 325i engine with it's loom, g/box + prop.
The 2.5 will slip in easily and plug straight into the car loom, connect up the prop and away you go - after the fact and when £Â£ is a better state then change the front struts + brake set up.
Make sure you buy a 2.5 engine with a compatable loom though ie there was 2 types - early + late. The early ones have a small diog port next to the fuel presure regulator and the late ones have a bigger one
Hope this helps mate.
Neil.
Neil.
fowler
- Boost Junkie
nelly i have mine running early engine with late manage ment and it was sound as a pound plus its better on later management as ecu was upgraded slightly
Nelly
- Gumbo
Ant
- Retired Team Member
you have to swop the early engines front pulley over for the late, and mount the VR sesor on the front cover, a post faclift Motronic 320 with plastic bumpers will have these parts already fitted.
a chrome bumper 320 will be a mission to swop over unless you are experienced with BMW wiring diagrams
Email FTW
diamondwhite
yeah i had to do all of the above as ant says on fowlers motor crank pully + sensors and fuel rail and a couple of other minor bits and pieces
The bare minimum you need to do to convert a facelft 320 to 325 is fit a 325 engine complete with inlet system and change the chip in the ECU.
The rest mentioned may be desirable, or even easier, buit is optional.
eltel
cheers to you all for the help will get cracking...
