2.5 M20 Head on Eta Block?
Project_E30
Post Wed Apr 05, 2006 1:34 pm
2.5 M20 Head on Eta Block, will this work??
Any details would be great!
jimmybmw
Post Wed Apr 05, 2006 4:56 pm
only if it is latest eta.
first eta's only compatible with 320i/323i head.
Project_E30
Post Wed Apr 05, 2006 5:00 pm
jimmybmw wrote:only if it is latest eta.
JonB says the opposite that I need an early Eta block.
HAS ANYONE DONE THIS ALREADY???!!!
jimmybmw
Post Wed Apr 05, 2006 6:23 pm
i'm building one at the moment.
my setup is a second version eta with polished 325i head, schrick cam shaft, inlet manifold with bigger and polished ports, M30 injectors and ECU, alpina 6-branch, remapped, shaved head for higher compression, x-rohr so you can measure emission on 6 cilinders...
trust me, it's not just a bolt on.
there are a lot of sites, even in english, that have lots of info. just use google.
check out this one for example. http://www.strictlyeta.net/
Finny
Post Wed Apr 05, 2006 6:42 pm
pardon my lack of knowledge but what car is the eta block from?
m-dtech
Unapproved Trader caution
Post Wed Apr 05, 2006 6:47 pm
i was under the impression that the 731 head was what was required because the 2.0 has flat pistons...
Martinaston
Post Wed Apr 05, 2006 7:18 pm
OK so if iyou use the 320 head on the 2.7 block what is the compression ?
And what would it be with the 325 head ?, bearing in mind that the 325 pistons protrude from the block unlike the 2.7. so i assume it would be lower :?
There is NO nucleus.
Project_E30
Post Wed Apr 05, 2006 7:32 pm
Finny wrote:pardon my lack of knowledge but what car is the eta block from?
Off topic: Do you have any more pics of your car as I haven't seen many with Mims fitted.
If you could post or e-mail me a few that would be great.
