Tapping sump for oil return
Toby_Unna
Boost Junkie
Post Sat Mar 04, 2006 10:55 am
feeling in a mood to get things done this morning so i think i'll drop the subframe and sump to tap it for the turbo oil return
only question is what size thread shall i tap it to?
i'm thinking i want a lot of flow, so i was going to tap it to the size of the smaller power steering pump banjo connection, which is something like m14 x 1.5.
i haven't sorted the return pipe yet but i guess if i do it this size i can use PAS pipe/connections if all else fails.
any thoughts (i.e. is that too big)
not sure where i'll get the tap from though, mine don;t go that big :cry:
Ant
Retired Team Member
Retired Team Member
Post Sat Mar 04, 2006 11:17 am
Use a surface mounted return fitting Toby, the Landrover/320D unit is cheap and easily found, alternative is the merc C250TD unit, both accept a standard 5/8th hose no problemo, no leaks on mine in almost a year too
the sump is too thin and grainy to reliably use a banjo IMHO,
suface mount= 1x 10mm hole for return flow, 2x M6 bolts , job done fella :wink:
I have a spare Garrett retun fitting for the turbo if req btw ??
e30_Turbo
Boost Junkie
Post Sat Mar 04, 2006 11:30 am
just like this :D
Toby_Unna
Boost Junkie
Post Sat Mar 04, 2006 11:38 am
ok we'll just quietly forget that i've spend the last 15 mins filing myself a suitable tap from an old banjo bolt because i can't find one :D
that's good Ant, tbh seems a better solution to me. i've just heard too many people talking about tapping their sumps... mostly on e30tech winkeye
just incase you know - what's the bolt spacing for the mount bolts?
i'm assuming the same as either turbo oil inlet or outlet (i.e. approx 38.5mm or 51mm centre to centre)
you've got a few hours m8, gotta drop the subframe and have the sump off first!
if you have one spare you don't need i'll happily buy it :cool:
gcorky
Boost Junkie
Post Sat Mar 04, 2006 12:19 pm
is that below the oil level?
525 sport
Toby_Unna
Boost Junkie
Post Sat Mar 04, 2006 12:39 pm
is what below the oil level?
gcorky
Boost Junkie
Post Sat Mar 04, 2006 12:46 pm
[img][img]http://img162.imageshack.us/img162/4203 ... 2qy.th.jpg[/img][/img]
i meant the return fitting below oil level or above.
heres a front mounted one. :D
525 sport
Ant
Retired Team Member
Retired Team Member
Post Sat Mar 04, 2006 1:57 pm
The return is above the baffle plate level and way above the oil level.
8)
I have some internal pix somewhere .......
edit: that silicone steam hose was a temp fit , we used that so see the oil flow was correct.
Jon_Bmw
Dangerous when thinking
Post Sat Mar 04, 2006 2:23 pm
As said don't be tapping it, its way to thin to be doing that, its asking for leaks. I used a gas fitting that clamps up to either side of the sump, seems to work very well for me and its positioned in the same place as in the picture G corky supplied.
