is it worth lightening my E28 M535i single mass flywheel?
also, if i do, will it need rebalancing afterwards? (i assume it will)
E28 M30 flywheel lightening
gareth
gareth
anyone?
Andy335Touring
Not sure if its worth it ?
If you do it don't take too much metal off, i don't know how much is safe to take off before it becomes a problem ?
gareth
i'm thinking that due to the lack of prvious experiences on here, i'll probably leave well alone.
what flywheel have you got andy?
Andy335Touring
E28 535
gareth
cool
does it 'feel' like a lighter one would improve things?
Andy335Touring
TBH put the money into buying a decent chip as you will be better off.
I had a Superchip in before my Emerald, not sure if they still do them though ?
gareth
i'll just get it cleaned up then... it's functional but not pretty!
">Sole founder of Fe2O3-12V it's a lifestyle
Templ8e30
I've lightened a few flywheels over the years and most recently the flywheel for my 2.7 M20, I took 3kg off it. You will definately need to have it balanced afterwards if you do. Mine was quite a way out and has been tested to 8000rpm which it'll never get up to so it is still strong enough not to explode on me
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
- Homo Hair
i'd say go for it.. helps take some weight off the front end albeit a tiny amount and rev up better
further toward the outside you remove the weight the more effect it has
gareth
cheers lads.
does anyone know a good place ito get it done? (ideally in sussex area)
