E30 CABRIO V12
S38B38
Post Sun Jan 19, 2014 11:42 pm
Well small update
decided to sell the S38B38 after complete rebuild http://alpina.123.is/photoalbums/251991/
i had bought a 750 with a fellow and me and my buddy split the car,, i got the V12 M70B50 drivetrain etc ,, he parted the car
I wanted the engine to be as good as possible,, i am a fan of V12 ,, Bmw and thats it
so i took the engine apart aaaaaaaand, let the show begin...
new waterpump,,+ 2 set of pulleys +wheel
all gaskets,,VICTOR REINZ or OEM..
All bolts/nuts new.. except crank rod+ camshaft
not like brandnew,,,,,,,,,
no way back.......
new bearings,, main + conrod
just an useless info Conrod bearings are ONLY by BMW and cost a fortune
cylinderhead refurb
Sv.H-Motorsport solution,, made by Max Lumens and imported by FATANDRE idea maker
this is a genius solution if/possible replacement for oem intake gaskets,, you use the oem,, but these are 3mm thick precise cut out of silicone and goes to head and under intake manifold((oem cost the same as a week holiday on a beach))
M40/M70 camshaft timing
Oilpan,, upper
exhaust manifolds were sandblasted and the heat shields........ CHROME :shock: :shock: got lost in Vanity
Most parts were sandblasted and powdercoated,,
lower oilpan and valvecover are black ,,all other parts shadow-silver-chrome ???
M70B50,,,,,,, 500 horsepower look :lol:
the white color is painted
/// stripes is mine/stolen idea the chrome stripes are mine idea,, this is all foil
The engine will be running on MegaSquirt standalone
Regards
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
gooseygander110
Post Mon Jan 20, 2014 12:15 am
looks interesting ......what box you using ? 8)
S38B38
Post Mon Jan 20, 2014 12:34 am
gooseygander110 wrote:looks interesting ......what box you using ? 8)
At first,, oem 4HP24,, i am waiting for an answer with the oem G560,, i will buy that gearbox if everything goes as planed
gooseygander110
Post Mon Jan 20, 2014 10:17 am
what about bellhousing and clutch to match up to the V12 ? Looking forward to updates !! 8)
leeparkes
Post Mon Jan 20, 2014 6:20 pm
Epic monster engine :cool:
Lurch320i
Post Mon Jan 20, 2014 6:51 pm
Ooooooo that's some great material to have with my dinner :-D
Can't wait for updates
rix313
Post Mon Jan 20, 2014 8:03 pm
:cool: :cool:
pianist
Post Mon Jan 20, 2014 9:00 pm
That is ewsome :cool:
How is it going to fit under bonnet though? :mad:
S38B38
Post Thu Jan 23, 2014 8:49 pm
gooseygander110 wrote:what about bellhousing and clutch to match up to the V12 ? Looking forward to updates !! 8)
The G-560 is an oem gearbox,,,
so i will either get the oem flywheel and clutc or use V8 solution
Kos
Post Thu Jan 23, 2014 9:06 pm
I have a 6sp 850csi gear box, flywheel and new clutch if interested :D
www.pukardesigns.com
IG Pukar.Designs
Fastroad
Post Wed Feb 05, 2014 11:48 am
Now that's a Fo0king great looking engine. The colour combination is :cool:
S38B38
Post Thu Feb 06, 2014 10:52 pm
Tomorrow a S6S 560G will be picked up ,,,,,,,,,,,,,,,,,,,,,,,,,,,,in UK winkeye
Kos
Post Fri Feb 07, 2014 1:04 pm
S38B38 wrote:Tomorrow a S6S 560G will be picked up ,,,,,,,,,,,,,,,,,,,,,,,,,,,,in UK winkeye
It has been collected :D
IG Pukar.Designs
suchy
True Zone Relic
Post Fri Feb 07, 2014 1:17 pm
What the absolute f*ck!!!!! :eek:
Now that's an engine swap 8)
S38B38
Post Fri Feb 07, 2014 8:54 pm
Thanks for your input Kos,,,,,,,, MANY THANKS :cool: :cool: :cool: :cool: :cool:
pukar
Post Fri Feb 07, 2014 9:00 pm
naughty!!
Kos
Post Fri Feb 07, 2014 10:47 pm
You're welcome !
Anything else you need just give me a call :cool:
IG Pukar.Designs
bab-91
Post Fri Feb 07, 2014 11:07 pm
:eek: It's always the Norse types that have some mad built!
Very cool! :cool:
IG - bab91
S38B38
Post Sat Feb 08, 2014 9:30 pm
overhauled Alternator,,,,,,,,,,,,,,,€€€€€€€€
Engine mounts,,
Manual Throttle-body
S38B38
Post Sat Feb 08, 2014 9:33 pm
S6S 560G vs G260/6
:mad: ,,,,,,,,,, :mad: ,,,,,,,,,,,,,,,, :mad: ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, :mad:
FormerMember
Post Thu Feb 27, 2014 5:46 am
Looking good, keep it up! :)
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
S38B38
Post Sat Mar 29, 2014 10:10 pm
Da,daaaaaaaaaaaaaaaa.........................................................
well guys
1 x v12 gearbox S6S 560 Getrag on M/S70
ahh, i wanna jump on you
G560 vs G280
N.B G280 is aprox 5cm ((2")) longer vs G260/6 ((M30B35))
N.B.,, G280 is on mounts and oem g280 bracket
bellhousings
OKEY....
SACHS,,, V12,,,,,,,,,, Ãaber Ãaber every BMW clutch i have seen so far
Sachs x 2 most likely the 2 titans in each class of its own
B10 BT clutch is the stiffest 240mm i have tried so far vs other 240mm but is made for DualMass flywheel ((Sachs 765 press is also heavy strong and stiff but made for Singlemass))
and then Sachs 280mm V12 clutch made for BMW,,,,,,, pretty much not the same size
the 240mm clutch bearing is almost a joke compared to the V12 280mm :
similair as G420
the shifting arm and selector rod may have to be shortened more or put more lenght in,, i dont know,, the gearbox came out of an UK E30 V12 conversion that was not finished
Tech info
GUIBO
S38B38
Post Thu Apr 17, 2014 12:06 am
fender182
Post Thu Apr 17, 2014 3:19 am
:notworthy: :notworthy: :notworthy: :notworthy: :notworthy:
2.1 318iS E30 - Weekend toy (2.8 loading...)
330Ci M Sport E46 - Work horse
335i M Sport F30 - Family car
Nobby_N
Post Thu Apr 17, 2014 8:28 am
Woahhhhhh! :D
S38B38
Post Thu Apr 17, 2014 10:47 am
Now,, it is the 750 brake cylinder,, that fits well
oilfilter housing,, radiator,, fuel lines and some minor things
after feew weeks it should be ready for loom installation and mapping etc etc
NoTurbo
Post Thu Apr 17, 2014 7:44 pm
Now THAT'S an engine!
zd3bx
Post Thu Apr 17, 2014 7:51 pm
Every time I see this, I poo poo myself...
E30 v12 manual, OMFG :D
Running video asap!
davethegoat
Post Thu Apr 17, 2014 8:12 pm
Very nice build! :cool: :thumb:
NoTurbo
Post Fri Apr 18, 2014 5:24 pm
What engine e management are you going to use?
S38B38
Post Fri Apr 18, 2014 8:39 pm
NoTurbo wrote:What engine e management are you going to use?
MegaSquirt.....
S38B38
Post Sun May 18, 2014 1:41 pm
Well small update,,,
2 x 6 cyl coilpack
8.5mm MSD
I have to get a smaller pulley wheel ,, or a bearing
and put another pulley/wheel here were the 8mm bolt is,, to get as much touch/grip on the crankwheel
i had the water pulley remade so i can run 1 belt instead of 2
lots of oil lines.....
a) 1 ,,main feed from pump to Accumulator.. pressure
b) 1 from accumulator to mastercylinder feed,, pressure
c) 1 from accumulator to steering box,, feed,, pressure
d) 1 from accumulator to oil carrier,, reverse
e) 1 from mastercylinder to oil carrier .. reverse
f) 1 from oil carrier to pump,, reverse,, big one
g) 1 from oil carrier to steering box,, reverse
got it ???????
all lines are high pressure and covered with stainless steel sleeve
the oil lubrication carrier,, i had to make new lines from flex steel hose,,
3 fuel lines 2 in 1 and 1 reverse
i had to modifie the gear stick,, so it would fit correct
NoTurbo
Post Sun May 18, 2014 3:42 pm
I can't wait for this to be running. Please make sure to upload some videos once it is turning over :)
S38B38
Post Sun May 18, 2014 6:29 pm
NoTurbo wrote:I can't wait for this to be running. Please make sure to upload some videos once it is turning over :)
Ok,, will do winkeye
sunnysr
Post Thu May 22, 2014 11:44 am
Hellish just seen this top job
