best place to buy megasquirt and what to buy
Toby_Unna
Boost Junkie
Post Sat Nov 05, 2005 5:21 pm
can't seem to get a decisive answer on this!
is this a good place? or can i buy it from somewhere in the UK? is this the right kit to buy?
http://www.diyautotune.com/catalog/mega ... f1de41b8cb
aside from the ecu kit, should i try to purchase the necessary sensors from the same place or can i get them in the UK?
so far i have a turbo (not the volvo one though!), 2x rover intercoolers to run in parallel, a load of aly tube and inlet plumbing. just need to find some m30 exhaust manifolds!
M5pilot
Post Sat Nov 05, 2005 7:21 pm
Its coming to the zone shop very very soon and at a decent price.
It will be built in the UK and there will be good very aftesales unlike if you bought it from overseas.
Currently working out prices.
Sal
m-dtech
Unapproved Trader caution
Post Sat Nov 05, 2005 7:41 pm
Toby_Unna wrote:can't seem to get a decisive answer on this!
the above kit is a version 1 kit. just hang fire on this just now... ;)
Toby_Unna
Boost Junkie
Post Sun Nov 06, 2005 12:09 am
Sal, i'll build it myself thanks :D
if you can get me a kit soon then i'm interested.
md-tech - not sure what you mean? anyway i need this asap for various reasons, is there something better i can buy now?
Jon_Bmw
Dangerous when thinking
Post Sun Nov 06, 2005 12:22 am
This is pinched straight from Ant:
you can run Ms as megasquirt fuel only
MSnS for squirt and spark
MSnS-E for squirt and spark extra, fuel, spark and higher res 12x12 fuel/spakr tables with dual table option( this is what myself and Fozzy are using BTW )
MSnEDIS for wasted spark
Not sure if that helps at all.
Toby do i spy intercoolers in your bumpers? :twisted:
Edit: I think this is the one you want, but i think there are other components you need to, que ANT when he comes along
m-dtech
Post Sun Nov 06, 2005 12:25 am
get the v3 main board. ms 2
glens garage do the kit
$180 i think + import tax
Toby_Unna
Boost Junkie
Post Sun Nov 06, 2005 12:52 am
Jon, i thought u had motronic and RRFPR? and i thought Mark was using the motronic for his spark? am i wrong and wrong? :D
md-tech, thanks for that. i put glens garage in google and found a lot of info but no website, any idea or do i have to ring them!
thanks both for info, very useful :cool:
Jon_Bmw
Post Sun Nov 06, 2005 11:32 am
Toby_Unna wrote:Jon, i thought u had motronic and RRFPR? and i thought Mark was using the motronic for his spark? am i wrong and wrong? :D
Yes i certainly do have the motronic cack and a FMU, no standalone for me yet. As for Mark I thought he was running fuel and spark, but thinking about it they may only be running fuel at the moment.
Heres glens garage:
http://glensgarage.com/
Toby_Unna
Boost Junkie
Post Sun Nov 06, 2005 1:32 pm
easy as that! cheers jon.
still no idea what to buy! i guess finding out what version Ant and Mark have would be a good start.
i'm a little concerned that buying a more up to date kit than these guys have might mean they're less able to help me tune it?
Mops
Post Sun Nov 06, 2005 9:41 pm
I got my MS2 unit from glens garage for US$250 + US$15 shipping to NZ.
arrived within a week.
Put it together, not, there are few tricks... make sure you pick the right version of MS. MS2 is more capable as a platform, but currently software has only basic fuel and spark functions. And ms2 at this stage does not run with 60-2 timing wheel late e30's have.
I'm doing install over newt few weeks and I'll update you guys.
1985/E30/325i coupe/5 speed/125k miles/shortshift/megasquirt II ECU controlling fuel and spark with custom ignitor and ICV mods/LC-1 wbo2/collecting parts for FI
Ant
Retired Team Member
Retired Team Member
Post Mon Nov 07, 2005 8:17 am
Toby, Diy-Autotune would be an excellent choice of supplier
get the V3.0 PCB, I would have but was not out when I purchased mine and Marks, it has a VR conditioner circuit built in which is a bonus, the firmware/software is the same accross both V2.2/3.0 so we can still help each other out , no problemo
Get the PCB, the componenets, the casing , you'll need the DB37 loom and connector( buy complete!!) the processor should come pre-programmed , you'll need to reflash it to suit the code variation you intend to use, me an Mark can assist with that, its the hardest part of setting it up.
Assuming you are building yourself, make sure and get the stimulator kit too, its invaluable for getting it all working, also allows you to run simulations of load vs rpms etc on the bench without needing the ECU in the car
You'll need an 02 sensor, makes sense to order the LC1 wideband while you've got your wallet out M8, an NB can be used but for tuning the WB is a must have.
HTH, sorry for the no reply on PM, been unwell of late dude :(
Toby_Unna
Boost Junkie
Post Mon Nov 07, 2005 1:16 pm
grand!
thanks Ant i'll go find a credit card and get ordering
sorry if i sounded pushy, just got good reasons to need to crack on with this
