What cars do large flange props come from?
appletree
Post Wed Sep 15, 2010 1:08 pm
I'm after a Prop to fit my 6 speed m3 evo box, i know i need the large flange type like the evo or 328 has but is there any other car that uses the same type as i only need to chop the flange off and weld it to my shorted IS one. :D
craigieeb
Post Wed Sep 15, 2010 1:17 pm
Can you not just swap the output flange over?
so take the one off the evo, box and fit a different one?
like it's done on the M30 conversion??
penton08
Post Wed Sep 15, 2010 6:01 pm
all the v8 engined cars ive seen have the larger flange, m30 engined cars have them too i think! fairly sure e39's do to.
vokietis
Post Wed Sep 15, 2010 6:12 pm
324td
appletree
Post Wed Sep 15, 2010 7:24 pm
I'm after the cheapest option so somthing like a e34 530 auto would be a nice cheap undesirable prop, if it fitted winkeye
FormerMember
Post Thu Sep 16, 2010 5:46 am
E30 M3
E30 325e (before '87)
E30 324td (maybe 324d also)
E36 328
E36 M3
These all are straight bolt on with 5 speed boxes, though i'd guess you had to shorten them with 6 speeder.
E28 M30 powered(?)
E34 M30 powered(?)
E32 M30 powered(?)
... those might also fit?
If you mean the "medium" sized flange. V8 and V12 have even bigger flanges..
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
