wot engines will fit straight into an E30?
spanky_doo
Hi all been a while since i posted blew my 325i last year an not had the heart to so much as look at it but i'm on a mission this year to sort it out. Gotta take the engine out to re-skim so i'm think of leaving the stock engine out and putting a bigger engine in instead. The only problem i've got is i dont know if any bigger bmw engine will fit straight in can anybody help? Would like a 3ltr if one will fit. Cheers
its nice to know i'm doing good for the environment.
polsta
put one of these in mate, goes straight in
TheHeap
Dezzy
- CR24v it's a lifestyle
M10, M40 and M20
spanky_doo
can anyone tell wot engine is in the 530 and will it fit?
TheHeap
I'm sure it's the straight six so i'm thinking it's a straight swap
Dezzy
Which 5. What year etcspanky_doo wrote:can anyone tell wot engine is in the 530 and will it fit?
E34 530's are V8 arnt they?
spanky_doo
i didnt think there would be any chopping and cutting but i wasnt sure if there would be a problem lining bolt holes up
Danhbmw
iirc, BMW had a thing a few years back saying that any BMW engine will fit into any BMW.
To prove their point they stuck a V12 from E38 750 into a Z3!
So in answer to your question....
TheHeap
Come again
Come again
spanky_doo
looked into the 5ltr v15 i'm almost positive that it doesnt fit into an E30 without the aid of a grinder
TheHeap
'V' what?
The obvious choices are the M30 3.5 ltr which is the old anchor from the 635, 535 & 735 - this is the straight 6.
Then there is the V8 found in the later 530, 730 which is a 3ltr V8. Then the 4ltr V8 from the 540, 740 etc. If you are doing a V8 swap it would be madness to put the 3ltr version in when the 4ltr is going to be the same effort.
The V12 fits in from the 750 & 850
You've also got the 24v 6 pots from the E36 such as the 2.5 M50 and 2.8 M52.
Also, the E36 M3 engine and the E34 M5 engine.
Look in the engine swaps/ forced induction section for ideas. They have all been done many times.
it all depends on what you want to achieve, how much you've got to spend and whether you can do the work yourself or need someone to do it for you.
spanky_doo
its touching 200bhp at the minute, i'd like it to be at least 250bhp and i'd like to get the 0-60 down from 7 seconds to 6 seconds
what was done to your 325 for it to be doing 200bhp?
Andy325i
That must be fast
Cook318IS
I didnt know that bmw were putting the vanos on the bottom end now?
spanky_doo
E30BeemerLad wrote:what was done to your 325 for it to be doing 200bhp?
its been chiped its not quite 200bhp its almost there
TheHeap
TUUUUUUUUUUUUUURRRRRRRRRRRRBO
Alpina 2.5 needed a different cam, exhaust and remap to get 192BHP.spanky_doo wrote:E30BeemerLad wrote:what was done to your 325 for it to be doing 200bhp?
Dude, it probably wasn't pushing out any more than stock power when you take into account age/ wear etcspanky_doo wrote:E30BeemerLad wrote:what was done to your 325 for it to be doing 200bhp?
Cypriotgeeza
Prob how you blew your engine in the first place matespanky_doo wrote:its touching 200bhp at the minute, i'd like it to be at least 250bhp and i'd like to get the 0-60 down from 7 seconds to 6 seconds
3.5litre engine all the way!!
Check my M30 build threads:
spanky_doo
Cypriotgeeza wrote:Prob how you blew your engine in the first place matespanky_doo wrote:its touching 200bhp at the minute, i'd like it to be at least 250bhp and i'd like to get the 0-60 down from 7 seconds to 6 seconds![]()
no it was my own fault i blew it, rookie mistake really i took the radiator off to make better access for the power steering and fan belt put it back on and didnt check there wasnt any air locks in the system, two junctions down the m1 and i realised there was. was on the way to santa pod for its first trip down the quarter mile needless to say well p***ed
spanky_doo
E30BeemerLad wrote:Dude, it probably wasn't pushing out any more than stock power when you take into account age/ wear etcspanky_doo wrote:E30BeemerLad wrote:what was done to your 325 for it to be doing 200bhp?
its been in the family for nearly 15 years, before i had it its been well looked after. it was on the on the rolling road before it was remapped, it was running 171bhp wen it left the showroom and 2 years ago it was running 168bhp hardly lost any tourqe either
- E30 Zone Meets/Events Team
+1Cypriotgeeza wrote:Prob how you blew your engine in the first place matespanky_doo wrote:its touching 200bhp at the minute, i'd like it to be at least 250bhp and i'd like to get the 0-60 down from 7 seconds to 6 seconds![]()
ross_jsy
Your car will not have 200hp, I would bet my e30 on that.
Easiest way to go about it is the HMS m30. If you fancy something lighter and revier and more modern, then m52 it with m50 inlet and remap. Will see you to a real 210-220hp.
If fixated on a 3L plus, then there is the S50 (e36 m3 engine) but from zoners who have done it, you are looking 5k+.
spanky_doo
[quote="ross_jsy"]Your car will not have 200hp, I would bet my e30 on that.quote]
i never said it had 200bhp i said its touching 200bhp, meaning 190s
AlpineAde
Dyno charts for the near 200bhp? Sounds like a strong engine. I just don't see 25bhp+ coming from a chip, though. 180-185 is gettable with some ease. 200bhp needs quite a bit of work. Even cracking mid 190s isn't super easy.
Have a look at an M52. A usable, modern low 190bhp engine that can be tweaked up a bit more with relative ease.
spanky_doo
just found a 2.5ltr cylinder head complete with cam shafts for £70. is it me or is that cheap???
AlpineAde
When you say 2.5, you're referring to an M50/52? These had two camshafts.
Yes...cheap! Unless it is garbage and needs a complete going over.
What mileage on the engine? Condition? Any receipts for work done? etc., etc.,
spanky_doo
doesnt say wot engine or if theres any reciepts it just says used but in excellent condition
ross_jsy
You will want to get it pressure tested and a clean up skim anyway.
Guessing you are going to stay with the m20 then?
spanky_doo
to be honest i just want to drive it again i'd like a 3ltr droping in it but its definately not going anywhere so i've got plenty of time to do so if i dont do it now
ross_jsy
Pardon?
If you want an "easy" and relatively cheap upgraded engine, just go down the m52 route. Will give you a true 190hp with the benefits of being modern. Been done a lot too so help is always at hand.
If not then fix up your current m20. But won't cost you that much more to go m5x, mine was about £700 all in.
