M30 clutch?
JGG1
Back in an E30 !
Post Mon Feb 08, 2010 9:38 pm
I have just bought back my old 335i Touring and the clutch is slipping.
The car was built with an e34 doner so I am geussing it will have a dual mass flywheel, I want to convert it to e28 single mass.
Anyway, where is the best/cheapest place to buy a clutch? I tryed euro today but even through work it was £150 + vat.
Any ideas or is that as good as I will get?
gareth
Post Tue Feb 09, 2010 12:39 am
E28 clutches are very expensive, i'm glad in a way my recent clutch problems were in fact the flywheel bolts falling out :eek: at least the cluch survived ok!
i got a recon one for about £110 iirc though a local motor factors - came in a ferodo box.
i've not seen any cheaper.
if you're looking for a E28 flywheel too, it might be worth talking to RPM on here. i think they were doing lightweight flywheels recently for the M30 but these take the cheaper E34 M30 clutch
oh, when you do it, theo gave me a top tip. drop the subframe and engine an inch or two on some longer M12 bolts and you can get access to the bellhousing bolts... just. not a fun or pleasant job though :?
Post Tue Feb 09, 2010 12:43 am
Or losen the mount nuts, drop the prop and tilt the engine back and take the g/box out that way, it's easier, i've done it 3 times, and going to be doing it again to drop in a lightened M30 fly.
gareth
Post Tue Feb 09, 2010 12:52 am
no good on mine, i'd only get 5mm rearwards on the head before the rocker cover pressed into the bulkhead.
with my engine in position, the bellhousing bolts press into the sound deadening :) the only clearance available is by dropping the lot downwards. depends on engine position and bulkhead massaging i guess. my bulkhead has never seen a hammer and the engine is in P2.5 on e30.de mounts
Post Tue Feb 09, 2010 1:02 am
My bulkhead saw a light tap with the biggest mallet I could find, and also I lost some of the sound deadening, and it's in pos 3 too.
JGG1
Back in an E30 !
Post Wed Feb 10, 2010 10:36 pm
Thanks for the input, I tried euro again today for an e34 clutch and even thats £115+ vat through work!
I don't know why but I thought they would have been alot cheaper for some reason. 8O
gareth
Post Thu Feb 11, 2010 12:06 am
most clutches are a lot cheaper. M30 clutches are fooking big though so it's no suprise they cost so much!
Post Thu Feb 11, 2010 12:09 am
You could do what i did, have the plate recon'd, cost me £50
gareth
Post Thu Feb 11, 2010 12:31 am
really? that's handy to know, where did you get that done?
Post Thu Feb 11, 2010 12:39 am
A place down the road from my mates garage, it was a trade price through him.
IIRC it was called Clutch Junction
