turboing my e30 325i
trav804
Wed Sep 16, 2009 5:39 pm
hi i got a turbo kit for my e30 its a home made manifold and exhaust to run a t3 the inlet has got uprated injectors but not to sure can i run this on a standerd bottom end??? and i will be running an intercooler? cheers for any help
trav804
Wed Sep 16, 2009 6:19 pm
and can i run the standerd ecu?
bigbhpwannabe
Wed Sep 16, 2009 6:51 pm
well the bottom end is fine ,the head gasket will need help though in the form of welded head ,with or with out wire o-rings standard gasket ,or mls gasket used with a stud and nut kit insted of standard bolts , you can use the standard ecu with a chip and riseing rate fuel reg but it is not the way to do itat all ,you need a mega squirt /vems or the like
gary
325i 4door turbo sleeper -
big turb
e36 carbonfibre wietech strutbrace for sale . 07919173179
charlE30
Wed Sep 16, 2009 6:56 pm
The standard M20B25 will run upto 10psi on standard internals, anything above that and you want an MLS gasket and ARP head bolts/studs. I've seen setups using the standard ecu with a rising rate fule pressure regulator but it'll never run properly. You'll need some sort of piggy back ecu or a complete standalone like megasquirt.
The above is just stuff I've picked up in other threads and I don't proclaim to be an expert.
BMW F31 335d xdrive
Gunni
Wed Sep 16, 2009 7:00 pm
You can run 400hp on standard gasket with ARP studs.
My friend has been running 1.5 bar of boost all summer long like this on a 8.8:1 compression engine.
He does have a welded head.
MLS is only for when you want your 9.7:1 engine to drop into the 8´s.
Gunni
@ 2012 VEMS group buy !!
piltv40
Wed Sep 16, 2009 11:41 pm
A Megasquirt fitted in an old ECU case and wired in as the original is the easiest
solution to your fuel mapping issue but you will need to add a wide band Lamda sensor to monitor the AFR. a 64 mm down pipe will easy the exhaust plumbing and will not povide too much back pressure.
A small engine bay air ducted intercooler is fine if you don't want to push the boost above what standard engine can reliably cope with 300-350bhp @10 PSI and you don't want to pull the front of your car to bits.
You will need to add a throttle position sensor onto the standard throttle body which is easy.
so, Best of luck
Gunni
Thu Sep 17, 2009 12:23 am
piltv40 wrote:A Megasquirt fitted in an old ECU case and wired in as the original is the easiest
so, Best of luck
Boost is totally irrelavent to engines durability/reliability.
Torque / HP are the only real factors to think about.
And stock M20´s can do over 400hp reliably.
Gunni
bigbhpwannabe
Thu Sep 17, 2009 11:57 am
another thing to consider is that your clutch will die a horible death ,unless you are gonna run barbie power :)
big turb
