I have fitted my replacement clio servo and this one doesn't clunk, so all is well with the world again.
But I fitted a spacer into the master cylinder which was about 15mm in length. This resulted in me only having about 50% pedal travel before the pedal would go no further. I also really had to push the master cylinder onto the studs on the servo.
So today I removed the master cylinder and took out the spacer and then fitted the m/c back. It still had to be pushed firmly for the last 10mm when it was on the threads. I now have full pedal travel and there is no apparent delay in hearing the servo being pushed when i press the brake pedal.
So really I'm asking is the spacer always necessary?
I will be bleeding the system tomorrow and the turd will go and stop for the first time.
M50 with clio servo - spacer query
You must have a different servo
- **BANNED**
How far into the servo does the pushrod lie?
On the standard E30 servo,the pushrod just pokes out.
Youth is wasted on the young.
dicko
Are you using standard e30 m/c ?
using E30 m/c.
The servo pushrod seems to stick out further on this servo compared to the other one I had. I'm confident it is OK.
Just started bleeding the brakes and the heavens have opened, grrrrr. I'm not lying in a puddle on the driveway bleeding brakes, no no
- **BANNED**
Live in the wrong county,bright sunshine here,not for long though,'er indoors is trying sunbathing topless,most distracting...
Headlamps on full beam eh Malc?
- **BANNED**
yup,eyes on stalks,be quite happy when it's time to go to work...E30BeemerLad wrote:Headlamps on full beam eh Malc?
