Ready 2 start 3.5 conv..needing flywheel- e34 535i please!
sedge
Post Wed Jul 01, 2009 2:24 am
hello quick couple of questions.......
am needing a flywheel to make start on 3.5 conversion have an engine from a 735i and have just got hold of a gearbox from a e34 535 sport, so if anyone can help please let me know,,
also i have heard you can use m20 loom on the m30 engine,, my loom has the 2 row ecu and the 735 loom as 3 row,, what ecu would i run it off on the m20 loom?? just want to make sure!!
blingsta
Boost Junkie
Post Wed Jul 01, 2009 11:42 am
ive got a e34 flywheel and barely used clutch as spare mate, im located in Essex, pm me an offer :D
sedge
Post Fri Jul 03, 2009 9:44 pm
helolo mate,, what would you take for it???
blingsta
Boost Junkie
Post Fri Jul 03, 2009 11:32 pm
i dont know what they go for mate, so make me an offer
Post Fri Jul 03, 2009 11:37 pm
You could use any m20 ecu, with a chip from speedtouch, thats what i'm running.
sedge
Post Sat Jul 04, 2009 1:32 am
is that on the m20 loom??? thing is my m20 doesnt have the tdc at the front pully like my m30 lump, its on the gearbox housing asits old skool,, what did u do about the mounting brakets??
sedge
Post Sat Jul 04, 2009 1:34 am
will you take 50?? i dont need the clutch,, + i would have to drive from bournemouth,, where in essex??? ta
Post Sat Jul 04, 2009 1:44 am
sedge wrote:is that on the m20 loom??? thing is my m20 doesnt have the tdc at the front pully like my m30 lump, its on the gearbox housing asits old skool,, what did u do about the mounting brakets??
No on an e34 manual loom
sedge
Post Mon Jul 06, 2009 2:01 am
ive got to use either my m20 loom (pre facelift) or the 735i one which is on the engine,, what do you rekon,,
my m20 ecu has the 2 row of pins
and the 735 is 3 row type,,,,
Post Mon Jul 06, 2009 8:52 am
I would be using the origional car loom
sedge
Post Tue Jul 28, 2009 1:21 am
rite,, well the m20 engine and box is out,, i have started preping m30 and have changed sump gasket,, and rocker and timing chain gaskets, fitted the spigot bearing and had to order flywheel bolts from bmw & wont be here till fri!!! so i have used m50 bolts for now,, as i dont think i can wait that long,
Am going to used the m30 loom which originaly came from 1992 735i,, Will i need to change any of the wiring to make the engine run?? i will be using the 7 series ecu
Post Tue Jul 28, 2009 9:38 am
I think theres only 3 wires to swap in order to get the blower, windows and eco dash guage to work.
Its all in the sticky mate.
