Welding in EGT sensor to manifold?
sk712
Post Thu May 28, 2009 7:32 pm
Hi,
I need to weld in an EGT sensor bung to my BTB manifold (325i). Can this be done insitu or is there a danger of getting weld spatter into the head?
Cheers.
appletree
Post Thu May 28, 2009 8:43 pm
Has it got to be that close or could you do it nearer 3>2 collector? You might get burrs going in to the head when you drill through before you weld if the valves is open on that runner.... :?
UweM3
Post Thu May 28, 2009 9:59 pm
Is the BTB manifold not stainless steel?
ShakeyC
Post Sat May 30, 2009 3:47 pm
You can do it in situ but not a good idea as it makes it difficult to get the angle to weld the bung all the way around. Is it just 1 egt sensor and where about you thinking of putting it?
