m30 conversion, E28 rad !!
blingsta
- Boost Junkie
i know a few peeps have used this, i was trying to fit mine in today, but figured out that the 2 metal box's on either end which normally support the bottom of a normal rad need to be chopped off ! has anyone else had to chop them off? theres no way i can get the e28 rad to sit low unless they are grinded away !
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
DRIFTBOY
I didn't have to chop anything to get mine in!
Are you sure it's an E28 M30 radiator?
I can measure mine after work this evening if you like..?
bigdek
get the grinder out dude
Ziggy
No choppy-choppy here either...DRIFTBOY wrote:I didn't have to chop anything to get mine in!![]()
bigdek
strange. are the rad mounts different on different models.
when i did mine on a 325 they had to go as the rad would not slide down far enough
Theo
I remember you going at them with a grinder!DRIFTBOY wrote:I didn't have to chop anything to get mine in!![]()
FormerMember
On facelift-models the bottom mounts have to be cut away. In pre-facelift models the bottom mounts are different and sit lower so you've to make little spacers to get the E28 radiator high enough (so you can bolt it in the upper mounts straight on).
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
DRIFTBOY
My memory....Theo325 wrote:I remember you going at them with a grinder!DRIFTBOY wrote:I didn't have to chop anything to get mine in!![]()
Theo, you are correct!
Sorry Blingsta, I did have to chop a bit off!
Ziggy
Mine's pre-facelift btw - so it's only Martin that's lost it.
DRIFTBOY
gareth
hackyhacky here too!
don't forget the tie wraps to hold the bottom away from the crank pully!
blingsta
- Boost Junkie
cheers guys, jobs all done, only one side grinded off and she sits in there perfectly !gareth wrote:hackyhacky here too!
