m30 e28 engine help needed
whipsey
do i need to block this water pipe outlet off ? whay can i use to block it with?
gareth
my late M30 has a plate over that water outlet. looks the same shape to me.
not sure if blocking it will affect the flow of coolant though, where did the pipework from that water elbow feed to originally?
whipsey
not got a clue gareth was told that if i leave it attached the elbow on there will hit the bulkhead
leeparkes
This is a pic of the back off my late M30 head and there is a plate blocking the hole
Hope that helps!
Hope that helps!
whipsey
looks the same i wouldn't think ther would be too much difference rally i'm gonna check the tk and see if the blanking piece is still available
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
