m50 convertion front springs
punk_sy
what front springs are you guys with m50s using ?
Ive got some -40 eibach 318is springs but there gonna be to soft right?
also got some -60 spax 325 springs but think there to low!?
any ideas i wouldn't mind it being -60 but on the IS with just -40 i used to bottom out that sump ! it is going to be an every day car but not too bothered about ride comfort.
cheers simon
cheers simon
I had 60/40 spax springs on my old 4 door M50 (car in sig) it was ridiculously low, they were new springs, so in theory it would only get lower, I had to raise the spring seats on the front and have alloy spacers made up for the rear to bring it up to a useable height.
I wouldnt buy spax again, ok for road use but they are a bit soft TBH
punk_sy
yea i thought they were a bit soft. you can push them down with your hands easilyDanThe wrote:I had 60/40 spax springs on my old 4 door M50 (car in sig) it was ridiculously low, they were new springs, so in theory it would only get lower, I had to raise the spring seats on the front and have alloy spacers made up for the rear to bring it up to a useable height.
baptie0
i also have spax, they are 40mm drop all round and i have bashed my sump a couple of times.
what is the best option to upgrade using original mtech shocks?
Eibach and H&R seem to be the most recommended for any E30, ive bought some H&R -35, Bob_S has these with bilstein B8's and sprints, watching his M50'd car round Oulton Park they looked more than up to the job
I'm going for a 40 drop front & rear on the touring, they should be fitted this weekend.
I wanted H&R or Eibach but touring owners get well & truly reamed on the cost of springs compared to the cost for saloons, so I bought some Weitec springs and am using Bilstein B6 front dampers.
punk_sy
wheres the best place to get the h&r springs from last time i heard they went way up in price?DanThe wrote:Eibach and H&R seem to be the most recommended for any E30, ive bought some H&R -35, Bob_S has these with bilstein B8's and sprints, watching his M50'd car round Oulton Park they looked more than up to the job
Depends where you buy them from, I searched for ages and eventually got them for about £111, other suppliers were wanting £150-£160 odd which is a plss take
£300 for a touring, robbing barstewards!
punk_sy
ouch that's expensiveE30BeemerLad wrote:£300 for a touring, robbing barstewards!
Give this lot a try, it's where I got my springs from and they carry a few different brands
http://www.europerformance.co.uk/pages/ ... gory=suspn
They are expensive IIRC,
These - clicky - were about £30 cheaper a couple of months ago! Seems like everywhere is jacking the price up
baptie0
has anyone converted 51mm front struts to coilovers?
jaistanley
If you look in the motorsport/trackday section of the forum there's lots of info on that...
I had the H&R springs on my iS and loved them. I have just fitted a second hand set of 325i ones to my S50'd car.. I'll have to let you know how it sits, I left a hub in coventry and cant get it till Friday!
Jai
Jai
punk_sy
yea that would be cool.post some pics upjaistanley wrote:If you look in the motorsport/trackday section of the forum there's lots of info on that...
Jai
jaistanley
Trouble is, the dampers I've fitted are brand new E36 M3 Bilstein B6's. Not sure if they'll make it sit high till they wear a bit. I shall try my best to get it on the deck tomorrow (I only have to fit two track rod ends, a droplink and a hub).
Jai
Jai
SCOTT325SE
Jai,jaistanley wrote:Trouble is, the dampers I've fitted are brand new E36 M3 Bilstein B6's. Not sure if they'll make it sit high till they wear a bit. I shall try my best to get it on the deck tomorrow (I only have to fit two track rod ends, a droplink and a hub).
Jai
how did you get on with pics of the car? Have any of you boys gone back on your decisions and bought different springs yet?
The H&R im using now with B8's are perfect, if I did another car these are what id use
This is my touring with M50 donk in sat on Bilstein B6 dampers and Weitec 40mm springs front & rear.
The car hasn't seen any use though so will probably settle more and it has 60 profile balloons instead of 55
whipsey
mines sat on -30's not sure of the make though there was a write up about them on here a while back i think i'm going to have to fabricate a sump gaurd though just in case
