Another swap question!!!
toughguych
Post Sat Feb 28, 2009 9:27 pm
I have a 325 1989 E30
M20
All I want to do is swap my motor for a bigger one.
All the options, all the mods,all the hassle?
If I get a lump then what one? E30 M3, silly prices.
E36 M3? Prices?
335? Prices?
I have not got a clue about swapping.
My mechanic says give me 2 days and a motor but I want to make it easy for him so will need extras like all those little bits,
you know the ones ( I Dont! )
I put a 4.64 LSD on two years ago, can I keep it?
Can I keep my standard 325 SE Touring gearbox?
How much is a 90k 325 Piper cam motor worth?
Cam done at 87k all belts inc cam renewed.
Any pointers to forum topics much appech.
Ride Safe
leeparkes
Post Sat Feb 28, 2009 9:58 pm
M30 or M50/52
M30 is a big 3.5 litre juice drinking lump of pig iron but it makes an E30 pull like a train!
M50/52 is a more advance 24valve engine with very good power but dubious reliability with the M52 alloy block,M50 is a 2.5 litre,M52 is a 2.8 litre
If fuel economy wasnt an issue id go M30!
toughguych
Post Sat Feb 28, 2009 10:29 pm
Fuel is not an issue!
Please tell more!
Post Sat Feb 28, 2009 10:35 pm
Drop a 3.5 M30 in there from a E34 5 Series, not expensive to do. 200bhp + :cool:
fuzzy
He who sleeps with "Gingers"
Post Sat Feb 28, 2009 10:45 pm
how deep are your pockets? thats the only real restraint on big ideas. and how easy/cost effective is your choice to tune up in future when you get bored of the power.you will get bored and want more,everyone does even though they originally insist 200/250/300bhp etc will be enough.
leeparkes
Post Sat Feb 28, 2009 11:08 pm
M30 you will idealy need an e34 535i engine and box,e28 535 radiator with electric fan,custom mounts (pm beefy) custom prop or use the flange off your 325i gearbox and the e30 prop can stay (though some say its not strong enough) im sure one of the downpipe flanges needs turning 90 degrees to clear the steering column,couple of wires needs swaping and your away!
M50,you will need an e34 525i engine,your m20 box/clutch/fly will fit onto it,vw golf or clio brake servo,e36 engine arms then gearbox mount mod(gearbox will sit at a different angle)then you have the butchering of the exhaust manifold to clear the steering column(much more brutal than M30 mani mod) then swap a few wires and your away!
M52 swap is very similar to the M50 swap.
if you have a decent budget for the conversion id go M52 with m50 inlet manifold and remap,you would see 210-220bhp plus they are light!
Post Sat Feb 28, 2009 11:14 pm
M30 is the easist way to gain power, amd I think its worth it.
Can say anything on any other conversion as i've only done the m30, easy. :cool:
blingsta
Boost Junkie
Post Sun Mar 01, 2009 9:21 am
ive also done the m30 conversion... found it to be very easy..
toughguych
Post Sun Mar 01, 2009 6:37 pm
Many Thanks Guys,
I was wreckoning on £2500 all in inc new uprated brakes.
Thats the motor, 2 days labour at £30ph.
All " sundries " .
I dont want to start working on the donor motor so how much to buy a good solid maybe even slightly tuned
M30 with box?
Is there a " how To " guide on here?
Post Sun Mar 01, 2009 6:46 pm
Right, slightly confused here.
£2500 for all bits including labour.Can you break that down for me??
toughguych
Post Sun Mar 01, 2009 6:56 pm
Throwing numbers in the air:
£600 Motor/box and all bits?
Two days ( 16 Hours ) @ £30ph = £480
Brakes £500?
Thats £1580.
Forgot to mention new tyres as my F1's walls are shot £400.
Thats £1980.
Plus fitting of brakes labour and a couple of hundred quid left over for any issues.
What you think?
leeparkes
Post Sun Mar 01, 2009 7:01 pm
All the bits to complete an M30 conversion went on here a couple of weeks ago for £600
fastdiablo
Post Sun Mar 01, 2009 7:15 pm
Suspension ? ? ? . . .
Poss go for Bilstein B8s . . .
I reject your idea of reality and replace it with my own ;-) . . .
Post Sun Mar 01, 2009 7:22 pm
Sounds abit much, but having said that, I did do most of the work myself.
Total bill including polybushes all round was £1700.00 all in :cool:
toughguych
Post Sun Mar 01, 2009 7:27 pm
Suspension was something I an't figured in.
Got Pi lowering spring on with standard shocks at mo.
Was hoping they would do but maybe not eh?
How do you buy a 335 motor and know its sweet???
leeparkes
Post Sun Mar 01, 2009 7:32 pm
toughguych wrote:How do you buy a 335 motor and know its sweet???
Buy a donor car so you can hear it running,there is always a risk in buying just the engine!
Post Sun Mar 01, 2009 7:35 pm
As above, i wouldn't really by an engine unless I knew who was suppling it.
toughguych
Post Sun Mar 01, 2009 9:33 pm
Would a 1989 735 motor be an M30?
DRIFTBOY
Post Sun Mar 01, 2009 9:36 pm
Yes! :D
leeparkes
Post Sun Mar 01, 2009 11:25 pm
are'nt the 735i manifolds different to the 535i manifolds?
Post Mon Mar 02, 2009 12:18 am
Yes but if the engine is the same, surley e34 manifolds would fit? :cool:
DRIFTBOY
Post Mon Mar 02, 2009 12:23 am
They do! :D
Post Mon Mar 02, 2009 12:26 am
Well he's got his answer then, get the engine, hunt roung for the manifolds from a scrappy, and away you go :cool:
toughguych
Post Mon Mar 02, 2009 7:29 am
Its an auto 735 so box no good.
Kinda got my answer but could really do with a guide and list of all parts to do the 335i conversion.
I am surprised there is no how to guide here or maybe I just an't found it yet.
Cheers.
DRIFTBOY
Post Mon Mar 02, 2009 10:38 am
Post Mon Mar 02, 2009 6:42 pm
Some M40 manual boxes do mount up to the M30 engine.It's all in the above post :cool:
toughguych
Post Mon Mar 02, 2009 10:24 pm
Thanks Driftboy,
Lots to take in!
So how does driving a 335 feel over a cam'd 325 with chip?
Post Mon Mar 02, 2009 10:37 pm
Alt quicker than a chipped 325i, as mine is a chipped m30 now.
You'll love it.
I still can't drive it at a respectable speed winkeye
It feels like it just wants to keep going on and on and on and on and on and on :cool:
DRIFTBOY
Post Tue Mar 03, 2009 12:40 am
I've not driven a modified 325i, only standard ones, but with the M30 engine it does pull well from low revs, and it pulled hard enough for my mates (almost standard U.K. model)Scccooooooobbbby Impreza to not be able to keep up down a dual carriage way! winkeye
Most n/a M30 E30s can run high 14s on the quarter mile, not bad for the cost of them! 8)
Post Tue Mar 03, 2009 7:46 am
Not tried a scooby yet, everytime I see one it's either going the other way or quite a few cars infront :cry:
Post Tue Mar 03, 2009 10:27 am
:lol: Rav
Post Tue Mar 03, 2009 8:28 pm
Someday I will mate, theres loads round here giving it the biggun' :cool:
fuzzy
Post Tue Mar 03, 2009 8:30 pm
Rav335uk wrote:Not tried a scooby yet, everytime I see one it's either going the other way or quite a few cars infront :cry:
scoobys and most evos are easy.
Post Tue Mar 03, 2009 8:48 pm
Fuzzy, with your 4pot turbo, anythings easy pray winkeye
gooner1
Out humping Reindeer
Post Tue Mar 03, 2009 9:17 pm
I may have a 324td washer bottle for sale soon, if anyone is interested.
