AFM removal on M20 what did you do?
Post Fri Feb 13, 2009 6:47 pm
Just wondering what people have done once they have removed the AFM on an M20 really
Big pipe with a cone on the end? Stock airbox with a pipe section.
S14 Airbox?
What did people do then?
chu346
Post Fri Feb 13, 2009 6:59 pm
I used a stock box with pvc pipe, looked factory :)
march109
Post Fri Feb 13, 2009 7:00 pm
Cone filter attached to the MAF unit, going to try sort out a CF replica of the stock box.
reggid
Post Fri Feb 13, 2009 11:10 pm
stock airbox with K&N panel with the exit opened out from rectangle to form a circle then attached the removale flange from entry of a M30AFM then a small straight section of silicon hose followed by a bend to the TB
E30 325is with M20B31
bodger
Post Fri Feb 13, 2009 11:21 pm
what is the advantage of removing the afm and what do you replace it with
reggid
Post Sat Feb 14, 2009 4:09 am
bodger wrote:what is the advantage of removing the afm and what do you replace it with
replace with nothing and use MAP or AlphaN/TPS or replace it with a MAF sensor. The advantage is better response and performance especially on modified engines.
AlpineAde
Post Sat Feb 14, 2009 5:05 am
Miller MAF.
Uses the stock airbox and their own chip.
Post Sat Feb 14, 2009 9:45 am
you got a picture Reggid? UniQ is the prefered weapon if this happens
Gunni
Post Sat Feb 14, 2009 12:00 pm
On a M20 I´d go for a 1bar absolute MAP sensor for the load.
Should be REALLY easy.
Gunni
@ 2012 VEMS group buy !!
reggid
Post Sun Feb 15, 2009 12:41 am
Simon13 wrote:you got a picture Reggid? UniQ is the prefered weapon if this happens
Excuse the dirt and crap, i have been doing some rerouting of hoses for the ICV and things are still messy. I am looking to get one of:
http://www.automac.co.uk/product/TB2383
You can see a plastic block that i bolted the aluminium flange from M30 onto, it is that thick so i could put a shape bellmouth so air going from the airbox into the silicon hoses has a nice transition rather than a sharp edge which would create turbulence. Its all sealed up with that nasty sikaflex stuff.
