1986 325i into my 1990 316i need help!!
Zobby
Post Thu Jan 08, 2009 4:18 am
i have been reading alot about the conversion and the mechanicals and fitting arnt a problem, its the wiring im starting to get concerned about!
i have a compleate C reg 325i 3 door and my 1990 4 door 316i. can anyone offer any help on the conversion im planning especially about the wiring!!!
Many thanx Rik
Ant
Retired Team Member
Retired Team Member
Post Thu Jan 08, 2009 8:56 am
easiest option is upgrade the engine to M1.3 so you need a facelift loom and triger setup fitted, then she'll pretty much just plug in dude
given you location, try Dave @ Fritzs bits
HTH :thumb:
Zobby
Post Thu Jan 08, 2009 2:42 pm
That sound s great i like plug and play!!
BUt im afraid that info went straight over my head!! lol
what is a m1.3 and triger setup?????
mr_dink
Post Thu Jan 15, 2009 3:02 pm
m1.3 is motronic 1.3 which is the management system fitted to post facelift cars.
Your C reg 325 is an earlier engine which uses L-Jetronic which is an old mechanical injection system.
If you fit the inlet manifold, injectors, ECU, AFM and engine wiring loom from a later (post 1987) 325 then it will be plug and play like Ant said.
Trigger wheel setup goes on the front of the engine, it's a toothed wheel with 1 tooth missing and a sensor to tell the ECU when TDC is.
Zobby
Post Sat Jan 17, 2009 7:01 pm
Cool i understand all that perfectly!
One question will the trigger wheel setup and knock sensor on the Creg engine be ok??
Also i have access to a scraped E reg 320i would the engine loom and inlet manafold be ok to use????? obviosly i would need the 325i, ECU, AFM and INJECTORS
Many Thanx Rik
