E36 318is into E30 316i TOURING
D4ZB3RT
HI JUST WONDERING IF ANYONE CAN HELP ME WITH ANY SNAGS ON DOING THIS OR TIPS AND IDEAS? I HAVE A LOW MILEAGE E36 318IS MOTOR & ECU, CAN I USE THIS ENGINE WITH THE E30 BOX? ANY HELP BEFORE I START WOULD BE MUCH APPRCIATED THANKS.
I WAS GOING TO DO THE 325I SWAP BUT THOUGHT ID DO SOMETHING DIFFERENT
Ant
- Retired Team Member
<CAPS LOCK OFF>
M42 or M44 ???
M42 is a yes with some mods( sump ) M44= forget it !
M42 or M44 ???
Email FTW
D4ZB3RT
EEK! ITS THE M44 I THINK ALTHOUGH ILL HAVE 2 CHECK,
IS THE M44 FORGET IT MEANING ON THE WHOLE JOB OR JUST FITTING IT TO THE E30 GEARBOX, THE 316I ENGINE IN THE E30 AT THE MOMENT IS VERY SIMILAR TO THE E36 316I ENGNE AS THE E30 IS THE LATER 1993 YEAR, JUST WONDERING WITH IT BEING OVER THE CROSSOVER YEAR WOULD IT MAKE THE JOB EASIER? OR AM I JUST TOTALLY CONFUSING MYSELF NOW? LOL THANKS
punk_sy
dude turn your CAPS off forum rules i think
There were no changes to the E30 when the E36 was introduced. No upgrading of the E30 to use any of the new parts (except an early form of EWS).
The E36 iS basic engine is the same as the E30 one, but most of the bits bolted on are different.
The most practical way to fit it is to have a complete scrap E30 iS engine, etc. available.
rix313
I did this change.
The main thing I found was the sumps are different, you'll need the E30 sump put on the e36 lump easy enough to do straight swap.
The inlet manifold is different tho don't see why you can't still use it but may want to look at using the e30 manifold?
Some of the engine plugs were a little different IIRC, so if using the E30 loom needs some thinking when it comes to connecting it up.
I think the mounts are different too.
Best to have the e30 lump as a donor if you have one.
robbo86
PARDON!?EEK! ITS THE M44 I THINK ALTHOUGH ILL HAVE 2 CHECK,
GrindCulture
I may be very wrong, but I've read somewhere that the E30 manifold flows better at high revs while the E36 one give very slightly better lower torque. You can fit the E36 manifold into a E30, but the E30 manifold wont fit into an E36.rix313 wrote:The inlet manifold is different tho don't see why you can't still use it but may want to look at using the e30 manifold?
Not in E30s any more
Nay
- Channel Island Crew
E36iS engines have knock sensors dont they? And different inlet manifolds (different shape, same thing, so E30 one can be used).
I heard that on a few 318iS fan sites when looking into them. Could be wrong though.
I have no ideas about what a knock sensor is... but i heard it a lot in the disscussions about differences and turboing them. Apparently, if you want to go down that root knock sensors help... but thats all i've heard.
There are some others, but all interchangable or not necessary to bother with. Other than that they're pretty damn similar. Internals are virtually identical.
Uni is killing the project.
GrindCulture
M44s have knock sensors, but with reference to turboing, they have cast cranks so aren't as desired as the forged crank equipped M42s.
GrindCulture
NayC wrote:And different inlet manifolds (different shape, same thing, so E30 one can be used).
D4ZB3RT
the is engine i have is from a 94 e36, is the 94 the M42 or M44 does anyone know? thanks
robbo86
Probably m42 thought dont quote me on that!
D4ZB3RT
I sure hope so! Ill be going to pick the engine up on Sunday, does anyone know how to identify the engines apart? Or where the engine codes are on the block? Cheers people
