m50 turbo, new turbo & wastegate.
baptie0
Post Sun Nov 30, 2008 6:35 pm
some pics of my m50 turbo rust bucket!!!
sump fitted with oil return.
m52 manifold upside down, welded together, t3 flange, Chinese t3/4 turbo, 2mm alloy decompression plate, gotech management. s50 fuel injectors
A/H fabrications intercooler
had it running today, very rich & black smoke. i need to make a exhaust system and get a wide band lambda kit to assist me with mapping the ecu. also the bonnet will require some adjustment, like a hole cut out to clear the turbo.
Image here she is in all her glory.
Turbo-Brown
Boost Junkie
Post Sun Nov 30, 2008 7:16 pm
Oh fair play dude!
That's gonna be awesome! :D
Are you able to get the M50 management to read from a manifold pressure sensor though?
baptie0
Post Sun Nov 30, 2008 7:44 pm
i am using a gotech stand alone ecu with a 1.5 bar map sensor.
BigBavarian
Post Sun Nov 30, 2008 8:23 pm
what sort of power are you looking to run?
Richard
baptie0
Post Sun Nov 30, 2008 9:14 pm
i am going to start of with 10 psi and see how it goes, the injectors are from m3 evo so i suppose 320 bhp could be a realistic goal. the price of fuel in the highlands is ridiculous so i cant boost it too much. does anybody have experience of these cheap t3/4 turbos? i am thinking it may be poor internal quality, although it looks ok. any comments/help welcomed.
cheers
BigBavarian
Post Sun Nov 30, 2008 9:52 pm
You should speak with james3320. He has a tourer with a m50 turbo running 451bhp and 400ftlbs. Altho its off the road at the moment while he strengthens the rear end to stop the diff ripping out the floor.
Richard
BadDave
Post Sun Nov 30, 2008 10:07 pm
Looking forward to seeing this one at one of our meets next year.
Turbo-Brown
Boost Junkie
Post Sun Nov 30, 2008 10:17 pm
Just a thought, if you've got the S50B32 injectors, they're supposed to run at 5bar rather than the usual 3bar.
That's not necessarily a problem, but start adding boost and the pump might start to struggle as the fuel pressure needs to rise along with boost.
baptie0
Post Sun Nov 30, 2008 11:01 pm
i see, thanks for that info, i thought they would be 3.0bar. will my 325i external pump be able to do 5.0?. i thought that the fuel pressure stays constant, but the fuel injector duty increases along with boost.
Turbo-Brown
Boost Junkie
Post Sun Nov 30, 2008 11:18 pm
I don't honestly know if the pump will be able to keep up, but it should be easy enough to upgrade I'd imagine.
The little pipe from the fuel pressure regulator to the manifold essentially tells the reg to keep the fuel pressure at whatever the reg is set to, above manifold pressure.
So if you've got 1bar of vacuum and a 3bar reg, the fuel pressure will be 2bar. That also means that if you've got +1bar in the manifold, the fuel pressure will be 4bar.
The reason the fuel pressure needs to rise along with boost is that, if we take an extreme case, if you had 3bar fuel pressure and 3bar manifold pressure, no fuel would come out of the injectors.
Firstly I guess you need to track down the 5bar reg to go with your injectors, or switch to the kind that run on 3bar.
baptie0
Post Sun Nov 30, 2008 11:25 pm
the regulator i have is adjustable, so a better pump and base pressure of 5.0 bar might be the answer. can you recommend a suitable pump?
Post Sun Nov 30, 2008 11:34 pm
S50 pump can be fitted to the E30 internal pump housing
baptie0
Post Sun Nov 30, 2008 11:53 pm
my pump is external. can i put a internal pump in my tank?
e30bmlover
Ac Schnitzer prophet
Post Mon Dec 01, 2008 1:16 am
this is going to be some weapon when its finished! i want videos and most importantly the dyno result posted! good work :D
Chuntington101
Post Mon Dec 01, 2008 7:57 am
have you got any more pics of the Exhaust Manifold? intrested to see how you ahve converted it to a turbo setup.
Also what is the overall comp. ratio with the 2mm plate??
Chris.
Turbo-Brown
Boost Junkie
Post Mon Dec 01, 2008 8:09 am
Think you can buy Walbro external pumps cheaply enough too.
baptie0
Post Tue Dec 02, 2008 12:11 am
Chuntington101 wrote:have you got any more pics of the Exhaust Manifold? intrested to see how you ahve converted it to a turbo setup.
Chris.
no idea about compression ratio, 2mm was the thickest i could get away with due to the length of the timing chain. sorry no pics of manifold, i can stick one on at the weekend. ordered a walbro pump today.
Post Tue Dec 02, 2008 9:12 am
baptie0 wrote:no idea about compression ratio, 2mm was the thickest i could get away with due to the length of the timing chain. sorry no pics of manifold, i can stick one on at the weekend. ordered a walbro pump today.
so you just slapped it in there and hoped for the best.. 8O
baptie0
Post Tue Dec 02, 2008 10:05 am
its not rocket science, the m50 can take boost on standard comp ratio. i decided to fit a decompression plate to allow more boost, i am on a tight budget so decided not to strip the bottom end. this engine is just a test bed to see what works. soon i will be building another m50, non vanos with machined pistons and steel rods, then buy a proper turbo and wind up the pressure.
Gunni
Post Tue Dec 02, 2008 11:11 am
your compression is in the high 8´s most likely now, which is totally fine.
Gunni
@ 2012 VEMS group buy !!
baptie0
Post Tue Dec 02, 2008 12:06 pm
sounds good to me!! hopefully everything will go smoothely, i am a little worried about the mapping but i suppose as long as the mixture is kept ok and i make ignition advances a little at a time all will be well.
Gunni
Post Tue Dec 02, 2008 10:25 pm
Not really that easy.
If you don´t have a solid base ignition map or can´t come up with one yourself,
you should simply take the car to a dyno tuner in your region and have them tune it.
To many people think tuning is just adjusting the mixture somewhat and using a ballpark ignition timing,
if the timing is retarded you´ll burn your valves in no time. Let alone run the risk of knock and detonation trying to run SAFE!!
Then there is air temp correction that people very often don´t have a clue to setup .
Gunni
baptie0
Post Wed Dec 10, 2008 12:57 am
got a sporty 255lph walbro external fuel pump this morning, i am going to fit it at the weekend,
set the pressure to 5 bar and see what happens!!. sorry no photos my pc has spat the dummy, having to do this my housekeeper/girlfriends laptop. i have to be quick,
she gets jealous if i am on the zone too long!!
baptie0
Post Wed Dec 10, 2008 9:36 pm
anybody know if an s50 clutch would fit my m50 flywheel/gearbox input shaft ?
if it wont then can anyone suggest an alternative?
Turbo-Brown
Boost Junkie
Post Wed Dec 10, 2008 9:53 pm
Don't know about the cover fitting the flywheel, but I think the BMWs all have a 10x29spline pattern on the gearboxes....although that's not really much help!
Post Wed Dec 10, 2008 10:20 pm
S50 uses a larger diameter clutch so the answer is no, although it will slide onto the input shaft
You'd be better with an M20 fly/clutch, uprated covers are available but I dont know where from
Nay
Channel Island Crew
Channel Island Crew
Post Sat Dec 13, 2008 11:24 pm
lookin mean fella!
Uni is killing the project.
baptie0
Post Sun Feb 08, 2009 4:22 pm
hi everyone
not much been done over the last month or so....but today got back into fixing the car again.
i replaced the original 325i fuel pump with an external wallbro 255lph one.
changed the antifreeze and bled the cooling system
finished making all the intercooler pipework.
just need to make an exhaust and squeeze the front panel back on. :D
baptie0
Post Tue Feb 10, 2009 10:44 pm
had the car started tonight after work, exhaust coming straight from turbo, it sounds good!!!
set fuel pressure to 5bar, it runs much better than it did on initial start up, revving up freely now,
still smoky but nothing major.
i have been reading a bit on here regarding holset turbos and am thinking that the cheap one i have might cause a bit of back pressure and therefore heat. what do you think? if i keep the boost low at about 10psi will it be a problem?
cheers :D
also does anyone have experience of strengthening the rear diff mount?
baptie0
Post Sun Mar 22, 2009 11:23 pm
just a picture of my downpipe that i am making,
it is 2.5 inch mild steel tube, cut and welded to create the bend.
it then steps to a 3 inch 90 degree bend which i purchased.
i am going to make the rest of the system using 3 inch tubing and have a 1 metre length of perforated tube to make a rear silencer.
i will take some better photos tommorow with it removed.
baptie0
Post Mon Mar 23, 2009 8:05 pm
a picture of my downpipe.
the rest of it so far.
my turbo manifold
baptie0
Post Mon Mar 23, 2009 9:02 pm
also got hold of some s50 throttle bodies a couple of weeks ago
going to make a inlet plenum over the next couple of weeks.
baptie0
Post Tue Mar 31, 2009 11:28 pm
hi guys
over the last wee while have been doing a bit of work on the car
got the front end back on, and i have fabricated a very crude bonnet bulge to clear the turbo,
a bit of black paint and its looking very scary.
i have been mapping the car on a bit of road near my house and i have to say that the car is going like a bloody rocket :D it goes like a normal m50 to about 3000 revs then it takes off! i have the boost set to .75 bar and there is no sign of detonation.
more updates soon as i get the diff replaced and my polybushes fitted.
scotty86d
Post Wed Apr 01, 2009 6:30 pm
Have you got any bigger pics dude, these are tiny.
baptie0
Post Sat Apr 04, 2009 1:39 am
good evening,
i have been thinking that i now need an oil cooler due to the increased heat my engine has to cope with.
am i right in thinking that i can swap my filter housing for an s50 type with provision for this?
can the m50 filter housing be drilled/tapped to fit a cooler?
anyone?
