M50 conversion cooling
**BANNED**
Post Sat Nov 15, 2008 10:16 am
Now I know that the accepted way of doing this is to use an electric fan.But,I have all that space between my E34 radiator and the front of the engine...I have tried the standard fan with viscous coupling and it fits,almost... the fan fouls on the radiator frame.If I was to trim about an inch of each blade it would fit.Any thoughts on the downside of this?
Ant
Retired Team Member
Retired Team Member
Post Sat Nov 15, 2008 10:30 am
as long aas you cut each blade the same the balance will be OK, issue is.....
any axial fan HAS to have the shroud quite close fitting to work effectively, otherwise the airflow will be accelerated off the blade tips, not pushed backwards as intended , this has a major negative effect on its cooling ability.
M10 fan is smaller and has less offset so would pop straight on, just the shroud to cut n shut to suit maybe ?
TBH electric is the way to go....
Post Sat Nov 15, 2008 11:30 am
Electric is by far the best solution tbh
jaffro
Post Sat Nov 15, 2008 1:36 pm
i used a m20 viscous fan a it was perfect but i used a 635csi rad that was very slim :P
Post Sat Nov 15, 2008 7:50 pm
You cant beat the twin speed fans, I had a switch on the dash that would fire the high speed relay, very handy at Santa Pod :D
jaistanley
Post Mon Nov 17, 2008 1:16 am
Isn't there a thin viscous fan that was originally fitted to the 324td e30's? That might do.
I vote for a decent electric fan though.
Jai
