M30 Clutch Issue
johnl320
Post Sun Oct 19, 2008 10:15 am
Hi folks
My 335 has a stiff clutch pedal and all the movement seems to be very high, ie. clutch fully disengaged with only slight movement of the pedal. Thers no slip and the clutch plate has plenty of material on it.
Am I right in thinking there are different bore diameters of both master and slave cylinder across the BMW range? My master cylinder is from a 5 series but my slave is 318 m40.
Clutch is from e28 and its a dogleg box.
Any help is appreciated :D
john
Post Mon Oct 20, 2008 12:12 am
Yes there are diff diameters, I think the norm is for a 7 series as a upgrade.
johnl320
Post Mon Oct 20, 2008 6:27 am
rav320uk wrote: I think the norm is for a 7 series as a upgrade.
what does that mean?
Post Mon Oct 20, 2008 8:56 am
Master cylinder from a 7 series as i read that somewhere last week.Will try to find the link a post it here for you mate. :cool:
Ziggy
Post Mon Oct 20, 2008 9:41 am
You're thinking of brakes. Don't know about your clutch issue John, sorry!
charlE30
Post Mon Oct 20, 2008 10:04 am
The 318 M40 clutch slave cylinder is listed as also being used on the E28 M535's so combined with the 5 series master it should work as it's designed to. How old are the master/slave? just wondering if with time they wear or become less efficient!! Could it be worth trying new parts with fresh fluid?? My clutch feels very similiar to what you have described...
BMW F31 335d xdrive
johnl320
Post Mon Oct 20, 2008 5:52 pm
Thanks for the replies chaps, Its not really an issue for me but the misses is only tiny so the pedal could be an issue in traffic.
Also if you push the pedal to the floor you get a nasty noise as if the clutch release bearing is being push further than it should.
I'm going to check part numbers and see exactly what I've got, its a dogleg box if that makes any difference.
cheers
john
Post Mon Oct 27, 2008 7:53 pm
Is it on the road John??
And what brakes you using? :cool:
johnl320
Post Mon Oct 27, 2008 9:12 pm
Just using standard 325 stuff car was a 316 carb so had to sort out vented front and rear disc conversion. Thats the first thing I did back in 2005 :roll: I have owned other e30s hence the name johnl320.
regards
john
Post Mon Oct 27, 2008 9:37 pm
What did you use for the eleccy fan set up, as wired mine up to a 2pin temp switch through a relay.
johnl320
Post Mon Oct 27, 2008 10:41 pm
I used two relays hooked up to a 7 series two speed aircon fan and controlled by a two speed temp switch from an e34 screwed into the side of my 635csi rad
Post Mon Oct 27, 2008 10:48 pm
That were my relay and fuse is situated, but to a 2 pin e34 temp switch earthed to the thermostat housing, the to a peugeot elec fan, supplied brand new without cost winkeye , to a relay, and going to run and test it tomorrow.
How long is left now?
johnl320
Post Mon Oct 27, 2008 10:53 pm
Mine needs the exhaust mounting, rear springs -40 and a little tidy on the bodywork on one side. But no electric in the garage and cold nights mean it'll sit there until spring, In fact no scratch that i'm off to Iraq in the spring for 6 months so hopefully on the road by early 2010. No hurry I'm building a motorbike as well. :D
john
Post Mon Oct 27, 2008 11:04 pm
Iraq???? om duty then.If so mate, that it easy out there.I'll probably have my e21 done by then too. winkeye
johnl320
Post Mon Oct 27, 2008 11:09 pm
Not my first time out there beleive me, just a job, same as anyone else.
john
Post Mon Oct 27, 2008 11:11 pm
suppose so, but your tour duty is long mate, i uppose you get a good tan :mad:
johnl320
Post Mon Oct 27, 2008 11:14 pm
Yeah wicked tan and lose fat, come back rippling with muscle which lasts about 6 weeks before I revert back to being a fat slob again :D
john
Jon_Bmw
Dangerous when thinking
Post Mon Oct 27, 2008 11:45 pm
Is that the military off road spec bikes you are building John? If so, put up a post about those, i'm sure a few would be interested. I'm sure i'll see you before you depart, but if not, stay safe! Despite being one of the slowest m30 conversions, I am confident it is one of the best.
johnl320
Post Tue Oct 28, 2008 11:02 pm
Cheers jon, the bike is along those lines all will be revealed when its finished. You're welcome up any time mate
john
