2.7 wont start
h2700
Post Tue Oct 14, 2008 5:32 pm
hi all ,
bit of background info ,
fitted a 2.7 into a 89 320i ,the 2.7 was originally running on early motronic managment (2 row plug ) ive used the later motronic loom and a chipped 325 ecu(3 row plug ) ,early maf meter and idel control valve ,
tryed to turn it over today , but to no joy . im not getting a spark at the coil ,ive tryed a good spare and still no joy ,
any ideas ?
thanks gareth :cool:
stonesie
Post Tue Oct 14, 2008 6:00 pm
Have you fitted the later front pully and crank sensor?
e30bmlover
Ac Schnitzer prophet
Post Tue Oct 14, 2008 6:10 pm
stonesie wrote:Have you fitted the later front pully and crank sensor?
good call mate! as said if you dont fit the toothed pulley you will @uck the engine within a matter of days.
h2700
Post Tue Oct 14, 2008 7:09 pm
yep got the toothed vibration damper of the later engine and the later tdc cranksensor from the 320
had a bit more of a fiddle , swapped the ecus over to see if it was the new ecu . made no difference still no spark at the coil .
going to check the primary and secondary resistance on the coils next see if ive some how got to dead coils :? but i doubt it .
only things i was a bit patchy about when i was fitting the loom was which plug the tdc sensor plugged into and which one the sensor on the plug leads connected to :-x
thanks 4 the input tho
**BANNED**
Post Tue Oct 14, 2008 7:45 pm
What happens when you connect a fused lead from the battery pos to terminal 15 on the coil?
Youth is wasted on the young.
secondtimelucky
Post Tue Oct 14, 2008 9:54 pm
Iv a feeling i know this one, attached to the underside of the steering column is a white connector block with wiring for the ignition in it. along with the main connector there is a single wire connection that is a complete bar-steward to see, that (i think :o: ) feeds the ecu when the ignition is on So, if its become dis-lodged ul get no spark etc
HTH :)
Wanted: Any old component speakers, complete or separate parts, let me know what you got :D
h2700
Post Wed Oct 15, 2008 3:37 pm
daimlerman wrote:What happens when you connect a fused lead from the battery pos to terminal 15 on the coil?
just tryed that and the coil still doesent spark and the icv started buzzing , :(
**BANNED**
Post Wed Oct 15, 2008 6:58 pm
I would think that rules out a wiring issue in the low tension side,then. I would suspect that the ECU may be the culprit,have you a spare you can swap in?
h2700
Post Wed Oct 15, 2008 7:01 pm
yeah still got original 320 i ecu that ive tryed just to see if it will spark and its made no difference .
Post Wed Oct 15, 2008 11:55 pm
If connecting the battery to the coil + does anything different than just turning the ignition on, then a wiring fault is exactly what you have!
Post Thu Oct 16, 2008 8:56 am
Thought I was getting a sense of deja vu with this thread!!
One thread per problem please. Don't post the same problem in more than one forum!!!!
This thread is now locked - continue in the thread in tech help!
