C101 Plug M30 Conversion
blingsta
Boost Junkie
Post Mon Oct 13, 2008 10:03 pm
Hi guys..
Just needed to clarify something.. Just realised that the heaters dont work in the E30, as its had the M30 conversion, ive read on the sticky that a few mods need to be made to the C101 Connector,
Where it says to connect the black and green wire (pin 15) to the starter motor, Does it mean i just splice into the black and green wire and run another wire to the starter, or do i just pull the wire of the plug and extend that to the starter?????
Thanks guys!
Post Mon Oct 13, 2008 11:41 pm
I need to know this one as mine is going in tomorrow, good job you asked :cool:
DRIFTBOY
Post Tue Oct 14, 2008 12:56 am
The black and green wire can be cut from the body side of the C101 and put to the small 'spare' spade connector on the starter.
You may also find that the economy-swing-o-meter-thingy under the rev counter won't work.
To get this going on mine (from a 1989 535i donor) I cut and swapped the black & white wire of pin 3 and the black and purple wire of pin 8.
Good luck!
charlE30
Post Tue Oct 14, 2008 1:29 am
DRIFTBOY wrote: You may also find that the economy-swing-o-meter-thingy under the rev counter won't work.
Good luck!
Cheers mate, I still haven't done this yet and was being to lazy to dig it up. Do you know if it's somehow linked to the OBC MPG calculation? as since doing my conversion the swingometer needle has always been at the side of full throttle and my OBC states I'm getting 7.1MPG!!! I'm hoping it will change with the for mentioned wiring mod.
Looks like we're going to have loads of 'big 6' conversions around soon.
Good luck blingsta :thumb:
BMW F31 335d xdrive
DRIFTBOY
Post Tue Oct 14, 2008 1:35 am
Sorry mate, I don't know the answer to that one, my obc never worked, and it's not there at all now.
But I would say that going by the 7.1 mpg that it must be linked, or that you drive like a complete loooony! 8O
charlE30
Post Tue Oct 14, 2008 1:39 am
DRIFTBOY wrote: But I would say that going by the 7.1 mpg that it must be linked, or that you drive like a complete loooony! 8O
Only now and again winkeye on average I'd say I'm getting more per tank than my girfriends F plate 325 tourer.
Going to alter that wire tomorrow :D
BMW F31 335d xdrive
Post Tue Oct 14, 2008 8:07 am
That sounds about right, when i had my m535 i had my feul economy on the obc down to 5mpg! proper lead foot is that :mad:
blingsta
Boost Junkie
Post Tue Oct 14, 2008 4:25 pm
thanks guys
blingsta
Boost Junkie
Post Tue Oct 14, 2008 5:28 pm
which connection on the starter does it go to ???? i dont wanna blow anything up! :cry:
DRIFTBOY
Post Tue Oct 14, 2008 7:01 pm
It can go on the small spade terminal on the solenoid, the easiest one to see by looking just under the inlet manifold.
blingsta
Boost Junkie
Post Tue Oct 14, 2008 7:18 pm
All sorted mate... cheers.. all wires connected as they should be... ive now got heaters !! :D The end is near... very near!! :D
DRIFTBOY
Post Tue Oct 14, 2008 7:19 pm
Nice one dude, what is still left to do?
eta
Post Sun Nov 23, 2008 1:55 pm
Your obc and swingometer is out because of the larger injectors. Buy one of Steve modules at www.seattlecircuit.com it should sort it out. Its why he has made them. Mine will be tried out on my 2.7 shortly.
Post Sun Nov 23, 2008 2:49 pm
Link don't want to work. :cool:
eta
Post Sun Nov 23, 2008 4:28 pm
it does now.
