328i into 320i
differ
hi im thinking of putting a e36 328i engine into my e30 320i,can anyone help me with a list of parts i will need to do the job,thanks for any help
benjy
Try reading the M50 developments sticky thread first. Its nearly all in there.........the rest is easily findable with a quick search.
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
- **BANNED**
Omi,he of Scumball Rally fame,has done this.He was trying to explain the complications caused by the ignition security system to us at the last Milkbar meet.He started with a complete E36 328i...may be worth having a chat to him.
Youth is wasted on the young.
Fitting a M52B28 is exactly the same as fitting a M50B25 with EWS. If you upgrade the 2.8 with a M50 2.5 inlet manifold, there will be very few external differences between the two engines, apart from the obvious difference in the block material.
