5 STUD CONVERSION???
MAJ-POWER
i'm looking to do a 5 stud conversion, clearly due to the majority of deep dish wheels being 5 and more widely available.
i would like to know what parts are exactly needed? and what sort of price am i looking at?
thanks
thanks
/// KAMI
just get 5 stud adapters cheapest way
MAJ-POWER
have you used them? i was thinking of that but heard people say its not such a good idea. but i need spacers anyway, cause i've got m3 arches fitted, so it could be a the easiest option.kami335isport wrote:just get 5 stud adapters cheapest way
have you completed your conversion?
oze30
NONO!!!! Extra stress on the wheels. AFAIK, the adapters are really 2 sets. 4x100-something then another into 5x120. All p, about 2.5-3 inches wide.
If you want 5 stud, easiest route is to grab E36 compact/Z3 stuff and plonk that on.
More difficult (read more expensive) is to get the E30 M3 stuff.
Personally, I would have gone for the E36 stuff as the E36 M3 brakes would fit the front fine. But I'm more than happy with my setup! Just need better brakes.
MAJ-POWER
what exactly do i need? theres quite a few e36 breakers i can get hold of. so parts from them, shouldnt be a problem, but z3, oooooops.
does anyone have the link for the adapters, as i forgot to bookmark them the last time i saw them.
oze30
Front legs, rear arms from the E36
E30 springs and top mounts
E30 M3 lower arm offset bush
Not sure if you need the handbrake assembly.
Search for it. It's been covered many a time!!!
MAJ-POWER
e30 parts, grrrr. i think its sticking to 4 stud spacers, or just the adapters.
jaistanley
See my posts in the tech section dude.. All awswered.
MAJ-POWER
oze30
They will allow you to fit 5x100 wheels. BMW is 5x120
MAJ-POWER
yeh, they do a range, just wanted to know how reliable the actual method is
jaistanley
They are vile.
Firstly you'll have to make sure your wheel nuts are exactly the right length otherwise you'll be forcing them from the hubface if they are too long, too short and you'll tear the threads out of the soft aluminium.
Secondly you will be relying on getting the wheels to run on a parallel surface comprising of four machined faces rather than two. No worse than normal spacers to be fair, it's just another consideration.
Thirdly: You'll need wheels with the correct offset to allow for the spacing effect, limiting your choice anyway.
Why the hell bother?
jaistanley
Fvcking council modding. That's right. Space your wheels out so the KPI is vastly incorrect then come back p!ssing and whinging about tramlining, vibration and sloppy handling.
jaistanley
Oh,
And this is the engine section.
I have the hump.
I have the hump.
MAJ-POWER
read the damn topic, its due to the bloody wheels. council modding?? shove your head in the back of your 14" bbs will you
Jon_Bmw
- Dangerous when thinking
Maj Power. They are so cheap, Buy them, Buy them now. You can't let this great opportunity slip you by. Quick before someone else buys them. GO GO GO.
Haterz !
Andyboy
- Alpina Colada
You are posting in the wrong section. This section is for engines, engine modifications and forced induction. It is not about wheels.MAJ-POWER wrote:read the damn topic, its due to the bloody wheels. council modding?? shove your head in the back of your 14" bbs will you
Simple!
oze30
Do you really want the wheels that every other chaved up council chariot has on already? 5x100 I think is Subaru, rover (range/land rover)
prices:
E30 M3 (proper way) will cost you close to 1k
E36 roughly half that if you can source the parts.
adapters: Written off car, busted bearings and huge amounts of tramlining Priceless! Oh,not to forget the fact that your wheels will have a different turning radius than before, so will possibly clout the body work,
prices:
