whats the best lump to get good torque
damo180
i recently bought a 2 door 320 to start a new track/drift build.i will be busy seam welding and cageing it for a while .would anyone have any idea what would be the best engine transplant for it because im looking for the best power and realibility as i am sick of fixing nissans every evening
appletree
AnM30 swop would be good for power, torqueand reliabilty and its cheep
damo180
call me stupid but what car is a m30 from because all i have ever delt with is the m40
maxfield
M30 is from the 535/635/735.
- Homo Hair
M30 is gonna suit..
jaffro
definatly m30 as i did have 1 not to long ago. and the guy who bought it off me took me out in it the other night now its in his track car a boy is it good. i wish i had kept it
a yeh it scared me
cliffybabe
- Powered by Nelly
i've got 194 torque out o the 2.7 using a eta bottom end,
and thats also with a standard cam soon to be changed
DRIFTBOY
M30 for grunt every time.
It's cheap, not that difficult and there's loads of info and experience from various members on here.
220ish lb/ft torque as standard.
damo180
what kind of bhp levels would u get out of a m30 engine in a e30 with the engine left standard
- Homo Hair
um.. the same they had when in the 7/5 series they came from..
FormerMember
.. which means 211hp if the engine is fron E32 / E34 (88->) and 218hp if it's out of E23 / E24 / E28 (<--87).
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
reggid
If its an option an S50B32 makes good torque more than the M30 and earlier in the rev range .......otherwise just look for as many CC's as possible M30 is probably the easiest option....you know the saying "there is no replacment for...........
FormerMember
Yes, that's true. But you can get 3 complete M30 engines for a price of one S50B32 engine.reggid wrote:If its an option an S50B32 makes good torque more than the M30 and earlier in the rev range .......otherwise just look for as many CC's as possible M30 is probably the easiest option....you know the saying "there is no replacment for...........
M60 is also really nice engine, lots of power and torque etc..
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
reggid
1 in the front, 1 in the middle and 1 in the back would go pretty hardJonsku wrote:Yes, that's true. But you can get 3 complete M30 engines for a price of one S50B32 engine.reggid wrote:If its an option an S50B32 makes good torque more than the M30 and earlier in the rev range .......otherwise just look for as many CC's as possible M30 is probably the easiest option....you know the saying "there is no replacment for...........
- Homo Hair
3?! Try 6 or 7..Jonsku wrote:Yes, that's true. But you can get 3 complete M30 engines for a price of one S50B32 engine.reggid wrote:If its an option an S50B32 makes good torque more than the M30 and earlier in the rev range .......otherwise just look for as many CC's as possible M30 is probably the easiest option....you know the saying "there is no replacment for...........
damo180
would anyone recommend the newer m3 engine running on a stand alone managment system
reggid
the recent ECU's in the M3 are far more advanced than any aftermarket standalone one so i would use that and perhaps a piggyback if you need to change something. There are some guys in the US working on ways to "editing" some of the maps and settings etc.damo180 wrote:would anyone recommend the newer m3 engine running on a stand alone managment system
damo180
so is there much work getting a m30 into a e30
turkey
just got mine finished and mot'd, wouldn't say it's hard but there is a a fair amount of time i would say, took me 3months, done most of it my own but also changed the rear arms,bushes,diff shocks, springs etc. although quite a lot of time waiting for parts/bad weather/going out and leaving it.
I recommend planning and prep first, make sure you got all the parts and a good idea of what you need to do, i think you will be able to get it done in a couple weeks (by weekends anyway). Better to find a 535i E34 and do it that way, then you can get some money back selling bits you don't need...
Theres a very helpful guide on here aswell
M30 is for those who want more power and tourque on a budget. S50B30/S50B32 is the way forward but is not cheap.
My brother has a good strong ex-E34 M30B35 and associated gubbins for sale, freshly removed and running fine.
oze30
certainly does!Jonsku wrote:Yes, that's true. But you can get 3 complete M30 engines for a price of one S50B32 engine.reggid wrote:If its an option an S50B32 makes good torque more than the M30 and earlier in the rev range .......otherwise just look for as many CC's as possible M30 is probably the easiest option....you know the saying "there is no replacment for...........
Karan
s38 is another option...great torque, particularly from the 3.8
damo180
it hard to know what to use then dose the people who have done the m30 conversion.crave more power after a couple of months or is there a permanent smile on your face
GrindCulture
It really all depends on your budget mate, if you don't wanna splash out on M-Power motors or the M60 V8, M30 is really the only way to go. You could always turbo it later on if it gets boring.
Not in E30s any more
FormerMember
Now i've driven ~3500km with my "335" and it still makes me smile with the torque. I'd like to have more top end power, though, so i'm planning to swap M60 or M62 during next winter. That should be "enough" for cabrio-cruisingdamo180 wrote:it hard to know what to use then dose the people who have done the m30 conversion.crave more power after a couple of months or is there a permanent smile on your face
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
oze30
Prime example...damo180 wrote:it hard to know what to use then dose the people who have done the m30 conversion.crave more power after a couple of months or is there a permanent smile on your face
Me. I had a 2.5. Bought all the things needed for a 2.7. didn't even get close to doing anything like that. Bought a 3.5 M30 after going for a spin inSpadges one, swapped that in but had trouble keeping uo with a tuned M20, so out it came and the M60 went in. I don't kmnow if I'd swap it out again, probably for a 4.6 if it blew. but that's if and when. If it goes bang when it's back in Oz, I see a nice LS2 can be had for about 750gbp, so that might find it's way in!
casper8r
You're talking about Oz, right? I'd be surprised to hear that a nice LS2 can be had in UK for £750!oze30 wrote:....when it's back in Oz, I see a nice LS2 can be had for about 750gbp, so that might find it's way in!
oze30
Equivalent to 750GBP. approx 1500AUDcasper8r wrote:You're talking about Oz, right? I'd be surprised to hear that a nice LS2 can be had in UK for £750!oze30 wrote:....when it's back in Oz, I see a nice LS2 can be had for about 750gbp, so that might find it's way in!
Karan
know any good sources for ls2s in the uk?
i need some sort of huge ass v8 in my car with straight thru pipes
that can scare the living crap outta people on the street
oze30
I'm thinking of getting the middle boxes mounted on flanges so i can replace with staright pipes and just have the rear box. On cherry bombs, Fook me it used to burble sweetly, but would backfire/burp to much and did my head in (also motorway jaunts were ear splitting to say the least!)
I take it you enjoyed the ride on monday?
Karan
yep always wanted to experience a v8 e30! awesome torque and would make a serious drift weapon!!!
oze30
lol.. yeah. .need to learn how to drift properly now. Weld up the 3.9 and away we go!
1an
DieselMeister
V8s are tasty. Maybe if torque is your prime motivation (and you're not on a tight budget) you could follow oz and get a 4.0 or 4.4. If the M5 lumps weren't so expensive and slightly high maintenance, I'd recommend that option. However the LS1/2/3 is much better value though if you're not a stickler for bavarian donks. No idea how easy the LS series are to fit but they come with plenty of horses and torques for not much outlay and can be souped to intergalactic / time travel spec for about 50 pence. Do it
