can i fit an e30 m3 box on to an m20b25?
midnight
Post Wed May 07, 2008 5:16 pm
as title states, and if so is the s14 box stronger etc.?
Post Wed May 07, 2008 7:07 pm
no it isnt, and why would you want to? £500+ for a box as opposed to £100
maxfield
Post Wed May 07, 2008 7:16 pm
The M3 box is a Getrag 265, which is rated to 265NM of Torque, where as the M20 Box is rated at 260NM of Torque.
But in reality I can't see there being much difference.
reggid
Post Thu May 08, 2008 10:02 am
maxfield wrote:The M3 box is a Getrag 265, which is rated to 265NM of Torque, where as the M20 Box is rated at 260NM of Torque.
They are able to take a whole lot more than that.............where did you get that rating?
johnl320
Post Thu May 08, 2008 6:39 pm
The clue is in the name of the gearbox :mad:
Ant
Retired Team Member
Retired Team Member
Post Thu May 08, 2008 7:29 pm
S14 box onto M20 is a non-no
M20B23 dogleg would fit, but its weaker so why bother ??
Leave it as-is Kev, fix it when it breaks, it Wont
jaistanley
Post Thu May 08, 2008 8:32 pm
I have a high mileage 325i gearbox on mine. I changed the oil and forgot to add the transmission vinration damper when putting it together. Rattles a bit at idle but still as sweet as a nut, even with the bashing I give it!
I always (through habit) double de-clutch and heel and toe and use the driveline to deccelerate more than the brakes too and it's fine with that n all. I guess the double declucthing will give the synchro's a slightly easier mind.
maxfield
Post Thu May 08, 2008 9:50 pm
Yes, I know they can take much more.
But, if I'm mistaken, didn't Getrag give the boxes these ratings?
e21Jason
Post Thu May 08, 2008 10:16 pm
A m3 box into a m20 no probs
The us spec 528ie manual came with the 265 box and a detable bell housing, ask some one on m3tech or another us forum to source a bell housing, then you just need the box.
I sold my set up about 5 years ago to racer in the kumho at the time.
But is you want a box upgrade use one from an m50 cheaper
Jason
jaistanley
Post Fri May 09, 2008 3:14 am
The trouble I can see with using the E36 boxes is that the canter of the engine is different so you'd need custom linkage and gearbox support wouldn't you?
Ant
Retired Team Member
Retired Team Member
Post Fri May 09, 2008 6:27 pm
^ easily done Jai, works fine the other way around.
linkage will tweak in a vice, and the cradle is an easy fix with a mig and some 40x40
Dont see the point though,Stock box easily hacks 400HP in good nick, and as Midnight owns my old SE now, that box is 100% pukka
Good info on the Bellhousing Jason :thumb:
e21Jason
Post Fri May 09, 2008 6:30 pm
hi
A custom gearbox support is an easy mod compared to tracking down a 528e belhousing, or mega expensive denrith
Or use a 525tds box, or some early m20 e34 520' came with a later gearbox but i can rember the spec of the of of my head.
Jason
Dave_M3
Post Fri May 09, 2008 6:31 pm
I'd love to get hold of an S50b32 box for the is 8)
midnight
Post Sat May 10, 2008 7:13 pm
alright guys thatnks a lot for the info its just that i got offered one and was just curious whether it was a worthwhile swap. so ill allow it but thanks again
