Power Boost Valve
dannywolf
Post Wed Apr 23, 2008 5:33 pm
Iv just bought a fuel boost valve (ebay) Item number: 280219855089 but I dont know how to install it.
The unit has:
a fuel in
a fuel out
a vacuum port.
Do I need to get rid of my OEM regulator? Which line do I pipe, from the tank or to the tank?
???? Thanks in advance!!
P.s its a 327i (325i head)
march109
Post Wed Apr 23, 2008 5:37 pm
Oh cool. they should issue these to Scouts and sell them as fire starters.
Any particular reason the BMW regulator isn't good enough? Just wapping more fuel in won't make the engine more powerfull.
If you must, no you don't need the OEM regulator, your replacing it with the fuel boost power fire starter incendury device special. The rest should come with instructions but fuel in comes from the fuel tank, fuel out goes to the engine.
dannywolf
Post Wed Apr 23, 2008 5:42 pm
Thanks!
Im going to turbo charge the sh*t out of it soon so Im gettin parts for it now. I havnt just been lured by ebays false dreams,
"but it said 15% more power??"
Im having trouble with the engine so Im replacing various bit.
jmc330i
Post Wed Apr 23, 2008 6:06 pm
dannywolf wrote: Im going to turbo charge the sh*t out of it soon so Im gettin parts for it now.
Will a power boost valve help much or be any use for a reliable turbo set up, especially one with big power (as it sounds like thats what you want)?
James
'91 325i Sport
'93 318i touring 16v
dannywolf
Post Wed Apr 23, 2008 6:09 pm
It seems the OEM regulator is connected in the end, at the pipe back to tank, so i remove this and reconnect the pipe to the point where the regulator connects to the engine?
dannywolf
Post Wed Apr 23, 2008 6:20 pm
Ebay says it will!!!!!! Im not really looking for too much power (well, i am, but the budget...)
The valve came with a gauge 2 so its nice to see wats up with the pressure. Iv crazy probz with the engine at the mo so Im trying to replace suspected parts. Its revving from 900 - 3000 by itself at idle and while driving. Iv cleaned the intakes and replaced the idle control valve.
Jon_Bmw
Dangerous when thinking
Post Wed Apr 23, 2008 6:52 pm
I can see it now. Big fat bright orange turbo....drip drip of some fuel from a nearby badly made regulator....
It'll all end in tears.
Jon_Bmw
Post Wed Apr 23, 2008 6:53 pm
Ebay isn't the seller you realise. :o You have just been had by an ebayer who needs to make some money to avoid the baliffs!
Post Wed Apr 23, 2008 6:59 pm
Ebay says.. It must be true!! 8O
Good luck with not setting fire to the car
Morat
Post Wed Apr 23, 2008 10:04 pm
OK, seriously - just throw it in the bin and put it down to experience. What the guys are trying to tell you is that it was a waste of money.
Best thing to do is list up your engine's symptoms under a different thread and hope that one of the experts gives you a helping hand.
gooner1
Out humping Reindeer
Post Wed Apr 23, 2008 10:14 pm
dannywolf, stay away from Ebay mate, and ffs NEVER go to view a "sport" in Birmingham or High Wycombe.
dannywolf
Post Wed Apr 23, 2008 10:45 pm
God dam ebay!!! It didnt come with an e30 adapter. guuuuuurrrrrr.
I know its not gonna just give me more power right away but I do plan on spending a couple of grand on mods so Im adding bits so I can tune my setup once everything is up and running. Im getting a turbo setup with injectors. Now I can view and play around with fuel supply. Im gonna have to educate myself through e30zone for this project. 3 months holidays coming up and an unexpected check for ┚¬2300 means TURBO E30 327i :mad:
Thanks for all the replies fellaz
andyr
Post Wed Apr 23, 2008 11:08 pm
Hey mate, I've not fitted a boost valve but they work along the same lines as a fuel regulator, I've got a mk1 escort with a tuned engine and put a fuel pump onit to fed the thirsty carbs and i needed to put a regulator on to well... regulate the pressure. These are adjustable as well. Filter king do an adjustable regulator. If you plan on running bigger power then ya right you do need to up rate your standard fuel pump in my eyes. I don't know alot about bemmers but i know a standard escort injection pump ain't no got for fuelling a cossie lump or a high powered cvh turbo.
Morat
Post Wed Apr 23, 2008 11:51 pm
:cry:
Post Thu Apr 24, 2008 12:18 am
Morat wrote::cry:
+1
Templ8e30
Post Thu Apr 24, 2008 10:51 am
FFS, if you plan to spend several grand doing a turbo conversion you'll be needing either a standalone ECU or a proper remap to get the fuelling and ignition right, the power boost valve won't help in any of these situations.
Fuzzy mentioned a while back that he'd had people refuse to work on his car while it had a power boost valve, several other members have had engine fires caused by these things, hell I used to have one as well. Bin it or sell it on again on ebay.
It's a waste of time on your car.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Ziggy
Post Thu Apr 24, 2008 10:56 am
[rant]
[/rant]
...oh what's the point - it's all been said, please just listen... :cry:
march109
Post Thu Apr 24, 2008 12:51 pm
Jon, Adam and I were talking about his powerboost valve the other day, he mentioned that Mark and he were chatting while the bonnet was open and engine running and they heard a wierd noise, turns out the power boost flame thrower was on fire (albeit a small one), Adam patched it up and KEPT it! He was complaining to me the fueling hasn't been right for ages :D .
He bought a new BMW one and is fitting it this week thank god! :eek:
oldroydsr4
Post Thu Apr 24, 2008 5:46 pm
you will need more than 2300 euros to build a 2.7 turbo m20.
easily the wrong side of £5k
327ire
Post Thu Apr 24, 2008 7:58 pm
eek. 5k? Fcuk that. ld love a turbo e30 but I really dont want to get into replacing the internals. That seems like proper big bucks. Maybe I should start a new thread "If you had ┚¬2300 what would u do to your 327i?"
Oh and the power boost valve,... I suppose il get rid of it then!
On another completely other different note,. does anyone want to buy a performance enhancing fuel power booster?
327ire
Post Thu Apr 24, 2008 8:00 pm
Oh yeah, iv been using my m8s name up till now (dannywolf)
Ziggy
Post Thu Apr 24, 2008 8:07 pm
Yep, twas a while ago that Adams sport nearly burned because of that POS... I've a feeling it happened again though?! Or it may be someone else that was foolish enough to keep one until it caught fire twice.
fuzzy
He who sleeps with "Gingers"
Post Thu Apr 24, 2008 8:15 pm
Templ8e30 wrote: Fuzzy mentioned a while back that he'd had people refuse to work on his car while it had a power boost valve, several other members have had engine fires caused by these things, hell I used to have one as well. Bin it or sell it on again on ebay.
Cheers,
Iain T
thats correct mate. 2 different tuners refused to work on my cossie engine whilst it had one of these PBV's fitted telling me to come back once id refitted the original.
march109
Post Thu Apr 24, 2008 9:39 pm
Ziggy wrote:Yep, twas a while ago that Adams sport nearly burned because of that POS... I've a feeling it happened again though?! Or it may be someone else that was foolish enough to keep one until it caught fire twice.
I pleaded with him last night to change it, he just phoned me tonight to say Ant said it may be the problem also. Good thing he has the stock one on the way.
Lesson learnt, lets hope OP's lesson isn't learnt when his car is a smouldering pile of shite.
