new monster v8 no 4.0 here !!! Start up vid on page 28 :)
Lurch320i
The whole lot polished will look amazing
FLG
Amazing build! You'll be happy to know I recently got my hands on the intake you made for your m20 and will be going on my 500+ whp build for next season. Might start a thread here on my drift car but figured I'd let you know! Had to find the guy who made it.
ross2009
josh ???FLG wrote:Amazing build! You'll be happy to know I recently got my hands on the intake you made for your m20 and will be going on my 500+ whp build for next season. Might start a thread here on my drift car but figured I'd let you know! Had to find the guy who made it.
FLG
No, i wound up buying it from Josh seems his plans changed for whatever reason
ross2009
O ok that's cool but yeah I'm the one that made it
FLG
Haha I might pm you when I get it in hand, unless it's quite obvious I was wondering how the tps senor was mounted. This is the car it will be going in btw.
http://www.r3vlimited.com/board/showthread.php?t=295277
Dont want to derail your build thread. Looking forward to seeing more though!
ross2009
Looks awesome, did he supply you with a throttle body too ?
I'll send ya a link of lots of pics as I was building it if ya like
ross2009
FLG
Thanks. I'll take a look! For some reason he had purchased another throttle body but it looks nearly identical to the one you had.
ross2009
Yeah bought another one as Id already sold my throttle body so couldn't send it with the manifold but you can pick them up pretty cheap
FLG
Yeah he included one. I assume the tps just gets screwed into the other side it looks like? Might just have to make some holes but dosnt seem like anything complex.
ross2009
yeah it does it just slots on to the butterfly shaft and screws down i think i made a little plate for the tps to screw to then bolted that to the side as my tps is quite small
ross2009
Got a few more bits for the rear and 5 stud conversion
Had a little test fit of the new wheels although there not actually bolted on or anything
The hub and disc pics before , I didn't realise that they were the wrong ones they are z3m ones not z3 ones but now I've bought brand new ones from the dealers
New bbs stainless valves
glenn
- Engine Transplant Services
where did you get the valve's from ross ?
ross2009
Ebay mate 18 squidsglenn wrote:where did you get the valve's from ross ?
ross2009
Small update I've got the rear discs on for mock up , the hubs need to be machined to let the disc go bk further for the hand brake shoes to be covered, as the hubs stick out to far, anyone that knows me knows I don't do things the standard way
Here's the discs behind the wheels there 300mm z4 discs on a z3 hub and will be running Porsche boxster rear Brembo 4pots
As you can see the shoes don't quite go under the disc hence the machining
As for the fronts there going to be a sleeved stub axle with e36 hubs
Blasted and cleaned up the front calipers they are staying red so they will be painted this week
Also took the xyz logo off too
And just some odd more bits that I've got new coil packs for the efi swap
And my new wheel bolts for the hartges
New front strut top mounts too, as mine are poo poo
Will have more updates by end of the week as I have some goodies coming from the usa , rear calipers will be here and the fronts should be painted
- E30 Zone Meets/Events Team
Did you get the Bolts from the site i gave you?
ross2009
Yes mateRav335uk wrote:Did you get the Bolts from the site i gave you?
ross2009
appletree
Looking great, they're some sexy looking wheels, bet you can't wait to see it sat down on them with the brakes behind them. Will the rear arche need rolling much then?
ross2009
appletree wrote:Looking great, they're some sexy looking wheels, bet you can't wait to see it sat down on them with the brakes behind them. Will the rear arche need rolling much then?
Cheers dude they do look awesome
I can't wait either mate just gotta finish off the 5stud and brakes then I can get the wheels together
Tyres and get it back on the ground
Not sure about the arches yet I shall see more when I get the hubs on
ross2009
Front hubs are tested fitted just got to get some new hub nuts
As the brakes and wheels are nearly sorted I thought I'd turn on to the fueling of this monster
This thing is gonna need some fuel supply,I've worked it out at wot on boost its gonna need at least 520lph
I wanted to stick with an Intank pump but for that flow it's not going to happen so it's going to have to be a twin pump system, I've decided to go swirl pot and twin pumps in the boot , now I know it's not going to be no track car to have the need for a swirl pot but there isn't no were to put the pumps inline underneath with out welding outlets on the tank
So it's the easiest solution with a low pressure lifter pump in the tank
A few bits and pieces
To feed this bad boy
More goodies to come next week
jmc330i
Will that even fit under the bonnet??ross2009 wrote:To feed this bad boy
I can't wait to see this finished
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
ross2009
ha ha yes it will its actually lower than the normal manifold carb and filter set up nowjmc330i wrote:Will that even fit under the bonnet??ross2009 wrote:To feed this bad boy
I can't wait to see this finished![]()
so will be fine the engine site quite low as it is
believe me i cant wait either
ross2009
glenn
that inlet ross.....
ross2009
pretty dam hot aint it glenn , its gonna house a 90mm throttle body tooglenn wrote:that inlet ross.....
glenn
90mm
you dont want to be starting that thing without the inlet pipe on......
it'll suck in anything that's not bolted down
ross2009
even small children ;)glenn wrote:90mm![]()
ross2009
jimbom30cab
- Tech 1 freak
Wow !
jmc330i
Now that's looks amazing
apart from the rusty turbos
James
'91 325i Sport
'91 325i Sport
ross2009
ha ha yeah it sits outside now with a cover unfortunatly , i will be getting turbo blankets for them so they dont look as bad
just got to get it all bolted down now and get all the fuel rails and lines plumbed in
looks better than that old carb dont it
manse73
Looking good Ross when work calms down I will call up for an 8 pot fix
bruv chariots rule
