update
Turbo-Brown
Boost Junkie
Post Mon Jul 11, 2005 9:38 pm
Hmmm, think their resistance should vary between 0 ohms and infinity ohms. The sensor is fed with 5v by the ECU and so it receives a signal which varies between 0 and 5v from the sensor, depending on vavuum / boost.
My understanding is that all MAP sensors operate like this, with the only difference between the pressure ranges being that is takes more pressure to get a 3bar sensor to read the same as a 2bar sensor.
Do you know what range your sensor is? Should be able to tell the Emerald what 5v means in terms of pressure.
Assuming that's the problem that is! :lol:
Ant
Retired Team Member
Retired Team Member
Post Mon Jul 11, 2005 9:49 pm
So its MAP dot enrichment then dude ?
can you switch over to TPS accel enrich instead and try the test again, may @ least shed some light on the assumed "duff" MAP issue
again its a maybe :lol:
mines still dead :oops:
lentec
Boost Junkie
Post Tue Jul 12, 2005 8:47 am
Thx again guys
I decided to hook the map sensor up to an old pc power suply (5v) and test it with a multimeter! the voltage changed when i suck the pipe! :? so the sensors ok i guess! so checked wiring diagrams and looks like i folowed the instructions too well! in the emerald manual the pic shows the map sensor wired as follows
A:supply pin 9
B:earth pin 30
C:signal pin 34
can you see the mistake?
gm map sensors are
A: gnd
B: sig
C: +5v
So 10 mins this morning with wire cutters and all is good!
it now revs up!!
thx yet again
Jon_Bmw
Dangerous when thinking
Post Tue Jul 12, 2005 11:01 am
Brilliant, when are you taking it for that all important test drive then?
Can't wait to do mine, but i'll have to finish the exhaust first as i don't think the old bill would like a sherman tank driving around without MOT from tomorrow :cry:
Been to busy polishing the misses car, don't see why i bother, Corsa + Purple =says it all really!
Turbo-Brown
Boost Junkie
Post Tue Jul 12, 2005 1:46 pm
Cool!
I wanna hear the supercharger whine! (said in whiny voice)
Fair play Len, what map did Emerald suply you with?
lentec
Boost Junkie
Post Tue Jul 12, 2005 3:33 pm
Well the test drive would have been tonight but ive got to sort my old girls pc
:-x
My boss has given me friday off work :D so hopefully then!
alex they sent it with the map for a vw v6 turbo i think!! enough to get it running but thats about it! if you want i can send you my map when i get it running a bit nicer.
Turbo-Brown
Boost Junkie
Post Tue Jul 12, 2005 5:01 pm
That'd be wicked! I've got the VR6turbo map too :(
glenn
Engine Transplant Services
Post Tue Jul 12, 2005 5:37 pm
this is the first time i've seen this topic :hammer:
and i've just read it start to finish,
very intresting, and i have to say it's nice to see you all freely exchanging
help etc. it's what this zone is all about.
i also have to admit, i've a soft spot for the whine of a blower!!
e30_Turbo
Boost Junkie
Post Wed Jul 13, 2005 10:36 am
glenn wrote:this is the first time i've seen this topic :hammer:
Glenn, we need to share the info so we can all atleast try and keep up with you mate :lol:
All this F/I stuff is so technical I'd be lost without the others help and reading/talking about others experiances and problems has helped us all progress I'm sure.
I'm just so jelous the rest have had some success, I still have a pile of parts and wires :cry:
lentec
Boost Junkie
Post Wed Jul 13, 2005 11:55 am
A few heads stand more chance than one :D
Ive been tuning cars for years and can usualy smell bad fueling or ignition from 60 paces :lol:
now its come down to setting up this lot its all difernt this mapping process is a lot to get your head round i cant tell if its too rich/lean what way the ignition (adv/ret) needs to go!
at the moment im still thinking its the fueling! stopping it reving up proper :?
if i build the throttle up slowly it revs ok! but if i blip it its like it cuts everything :? still ill have a proper look friday when my neighbours arent giving me :evil:
Turbo-Brown
Boost Junkie
Post Wed Jul 13, 2005 1:36 pm
Hmm, wouldn't be something like accell enrichment either doing too much or not enough would it?
Think you can set how long it lasts for so perhaps if it's accel enriching for too long, it might be choking it to death.
Can't wait to start trying to get mine to run :eek:
Ant
Retired Team Member
Retired Team Member
Post Wed Jul 13, 2005 1:51 pm
Me too, it runs off the priming pulse but no more after that :cry:
still have some comms issues, if/when I get my head around those I'll be en route to Fozzys to hook him right up :lol:
e30_Turbo
Boost Junkie
Post Wed Jul 13, 2005 2:35 pm
ant wrote:Me too, it runs off the priming pulse but no more after that :cry:
Dude, I'm having to buy a cable for the MS so I can hook it up to the PC, only found that out once I'd removed it and the battery, had the misses beat me for putting the battery on the hall carpet and then realised the cable is not the one I have!! F**k it....off to Maplins to get the right one asap!!
Always another problem just when you think you're getting somewhere
:lol:
glenn
Post Wed Jul 13, 2005 2:54 pm
i know what you mean mate,
this hot sticky weather isn't helping my patience either, better than rain though!
e30_Turbo
Boost Junkie
Post Wed Jul 13, 2005 3:38 pm
I just hope it's cold and damp when it comes to mapping time, this heat kills my M20, I don't bother driving it when it's past 25'c, just no go.....need a damn fridge plumbed into the air intake....hmmmm....I wonder :lol:
glenn
Post Wed Jul 13, 2005 5:06 pm
how much boost are you guy's gonna be running?
and what power outputs are you expecting?
Ant
Retired Team Member
Retired Team Member
Post Wed Jul 13, 2005 7:17 pm
Mark make sure and get a fully pinned straight through DB9( RS232) not a null modem cable.
Glenn, I'm starting low @ 5.5 Psi and working upwards from there, we certainly have the fuelling control in place, the turbos are capable of 16 psi and all the plumbing is hard piped so no real losses there.
The engine is the weakest link, Jim Naff in the Us destroyed his @ 15.7 PSi but that was after 80K boosted miles, and a lot of drag strip action, theres a video on his site of his car wheelieing away from the lights on slicks :cool:
as for power ???? I'd like a LOT, but I'll settle for a relaible and torquey 250 bhp ish
BBR back in '91 marketed a small T2.5 based turbo kit, with piggyback ECU and tiny intercooler, that made an honest 250 all day long @ 6psi, I have the mag article and dyno sheets somewhere :lol:
glenn
Post Wed Jul 13, 2005 8:10 pm
:offtopic: sorry!
ant, karan was telling me we met at a ford meet?
i've a memory like a sive, was it castle coombe?
did i have a rwd cosworth powered mk4escort.
again sorry if off topic
Ant
Retired Team Member
Retired Team Member
Post Wed Jul 13, 2005 8:13 pm
Glenn, I believe it could have been you is what I said to Karan, it would have been 6 years or so ago mind, as for the venue.... lost in the midst of time M8 :lol:
See you @ Gaydon though m8 ??
Turbo-Brown
Boost Junkie
Post Wed Jul 13, 2005 9:02 pm
I'm planning to run about 6 psi or so max. Hoping to make about 260bhp which looks like it will hopefully be achievable if that kit Ant mentioned made 250 on 6psi :)
I'm not so secretly hoping that my individual TBs might liberate some ponies :lol:
Essentially, I need at least 240 to get a similar power to weight as the 205 Mi16Turbo I'm building for my mate! Can't have the french beating the germans now can we?!
e30_Turbo
Boost Junkie
Post Wed Jul 13, 2005 9:29 pm
ant wrote:Mark make sure and get a fully pinned straight through DB9( RS232) not a null modem cable.
I will :D
e30_Turbo
Boost Junkie
Post Wed Jul 13, 2005 9:36 pm
Just as promised Alex, I wonder how that one mounts up to the turbo?
Jon_Bmw
Post Wed Jul 13, 2005 11:19 pm
There must be another connecting pipe either up or down, but its difficult to say, up and the turbo would be tight against the manifolds, down and it would be close to the engine mount.
Looks similar in ways to yours alex,
By the way i think the individual throttle bodies won't release ponies but racing horses instead!
Turbo-Brown
Boost Junkie
Post Thu Jul 14, 2005 8:09 am
Yeah, that is an odd one!
Guess there are a couple of bends missing in the photo which connect the two halves into the turbo.
Looks like the rear most manifold is missing a bit too.
Wonder if that's a takeoff for an external wastegate on the front one.
Look pretty neat though!
Did some more wiring last night so I've now got the ECU controlled fuel pump relay and also the main engine relay connected up.
Will hopefully get the TBs mostly mounted this weekend as I've enlisted the help of a mate and some bastard-files :)
Once they're on, I can hopefully finalise the wiring in the engine bay and connect up the fuel side!
e30_Turbo
Boost Junkie
Post Thu Jul 14, 2005 8:51 am
Alex,
There is a guy called JON VOLK, he's a e30tech member and I think he is now on here too.
He's running bike TB's on his M20 and as far as I know they're on and working, he may be of use to you.....
Just thought I'd mention it :D
lentec
Boost Junkie
Post Thu Jul 14, 2005 1:28 pm
tomorow it will be ready for road test :D
Just for fun i loaded one of the other maps that came with the emerald one for a pinto??
That made it rev alright! i think ive made a monster :twisted:
And i avent even fired up the charger yet :twisted:
Borowed other halfs digital camera that does video with sound so will try to get some kind of vid up tonight!
Jon_Bmw
Post Thu Jul 14, 2005 1:35 pm
lentec wrote:tomorow it will be ready for road test :D
With reference to the pinto, its an old ford engine, came in 2.0 or 2.1 i think. Was in the mk2 escort amongst others i think. NA though, but if it makes it rev it makes it rev!
We need videos!
Alex the flange came today, its wierd its everso slightly smaller but will work fine once i've enlarged the bolt holes, so now i'm in the process of making the two into one bit to bolt to it. I've come in for a break as its swelteringly hot outside. Its not fun welding when its 25 outside.
I'll get something in the post for you after the weekend probably.
Jon
Turbo-Brown
Boost Junkie
Post Thu Jul 14, 2005 1:41 pm
Mmmm, interesting about the Pinto map, guess it's a 2v engine so perhaps the airflow is more comparable to the M20 than the VR6
Len, if you want to keep the Pinto map but use the VR6 MAP sensor compensation, we found that an easy way of combining maps (too many maps I know) is to rename the file as a *.txt file.
You can then open tem both up and cut and paste the relevant bits accross before saving and re-renaming them as *.fig files again. Not sure if that's any help :lol:
Jon, glad it turned up alright! Don't need to send me anything unless you absolutely want to! :)
glenn
Post Thu Jul 14, 2005 2:21 pm
i too, have just come in from welding outside, i need a drink then its back to the grind-stone :lol:
e30_Turbo
Boost Junkie
Post Thu Jul 14, 2005 2:24 pm
How come I seem to be the only at work today?????
I'd rather be welding :lol:
glenn
Post Thu Jul 14, 2005 2:38 pm
i've been to work, but i start at around 2.00am!
so i'm usually home early afternoon :woohoo:
H35-IAN
Post Thu Jul 14, 2005 3:00 pm
ive just spent nearly a hour reading all this thread i agree with whoever said it this is wat the zone should be about fair play guys for sticking together on this after reading seeing and being interested in e30 turbos for a long time i may well have to do a turbo one next lhd obviesly though!! and keep me h35 for shows , summer use. :cool:
i give u all the best of luck achieving these goals fair play lads i may well need all ur helps soon myself lol!! :cool: :wink:
bmw 328i sport e36 :)
Sjoerd320i
Post Thu Jul 14, 2005 3:59 pm
Ian I am reading this thread to man over and over 8)
can't wait till I have the money and time for a car, but one thing is for certain(spel) it will be a cab 8)
329i turbo cab :cool: :cool: maybe even twin turbo :wink: :D
Jon_Bmw
Post Thu Jul 14, 2005 4:47 pm
Yes that sounds simliar, bugger thats crap, grind it off start again :lol: , got done what I wanted to though, just got to go to a wedding in bristol for the weekend now so the bodging will re-commence monday.
Have a good weekend chaps, get those turbos and chargers spinning up!
Good luck lentec with your testdrive, hope it rips!!!
Wilson
Post Fri Jul 15, 2005 8:14 am
Can't wait to see this video!!!!... :D
I'll be checking back here all day!!! :D
