I finally got around to fitting and wiring the LC-1 but i didn't get much chance for data logging as i spent a while messing with the settings and seeing if it would run closed loop on the ECU, oh and i had some relations come over to visit so that was three hours i couldn't work on the car
What speed do you guys have the LM programer set for the analog out put, i think i ended up using the 1/6 second setting. Real time setting had the readings jumping all over the shop and the slowest setting it didn't run as smooth on closed loop at tick over.
I think the fact that i've got a cam fitted and i'm only measuring the exhaust gas from three cylinders means the low gas speeds at tick over are making for an unstable AFR reading ?
For some reason i couldn't save the few logs i managed to do so i've done a screen capture of a 4th gear WOT pull from about 2k through to around 6k rpm.
Yellow = throttle postion %
Green = revs
Red = AFR
I'm not impressed by the AFR trace, all straight edges ? May be this is linked to the sample rate of the ECU data logger or some thing else ?
I don't know what that big lean spike about 5k was, a glitch ?
Looks like AFR wise i started of with low to mid 12's til around 3k rising to about mid 13's til 5k, then it starts dropping down to 13 for the last thousand revs.
Looks like (when i next borrow the lap top) i could start to richen the 3-5k mid range, try to get it below 13 and keep playing with it from there ?
Tick over as i said before was very hard to read because it was jumping all over from 11 to 14, as a gestimate it was spending most of its time in the low to mid 12's open loop which is to rich. I turned closed loop on to see what would happen, the readings stabilized more as it was trying to regulate its self, it was roughly speaking 14 to mid 14's which is a step in the right direction. It did tick over slighty more lumpy than before but by no means badly.
In the settings for the closed loop it can only make up to a 20%(default setting that i didn't feel i should adjust yet) fueling adjustment at the moment so the AFR's might have got a bit higher ?
I think i need some kind of X-pipe in before the sensor so it mix's up the gas so the sensor see's the gas from all 6 cylinders.
