Post
Wed May 13, 2009 10:54 pm
gcs325i wrote:How come your not running the powerflex bushes in the m3 position? and the exhaust looks good by the way.
Because the outer part of the bushes were put in wrong lol, so they are concentric.
I may just buy some M3 eccentric ones in due course.
The exhaust came out quite well, it is certainly in no danger of hanging too low and catching speed humps as everything it in OEM location. Nice & quiet too.
Dezzy
- CR24v it's a lifestyle
Post
Wed May 13, 2009 11:27 pm
Yeh non vanous with enlarged throttle body ported and polished head lightened flywheel and re map. Cat do motorsport only cams for our motor which is designed for standard followers etc. Inlet is 278 exhaust is 272 which i have been told will work perfect with the other mods
Post
Mon May 25, 2009 5:48 pm
Did a bit to it today but not much achieved really.
Got the steering rack back into place and all bolted up. Started trying to bleed the brakes the old fashioned way as my btother forgot to bring the eazibleed thingy, managed to get the fluid through to the rear wheels but nothing happening at the front, my brother suspects due to the ABS system, so I'm going to buy an eazibleed kit so that some pressure is put through.
The front antiroll bar just wants to hit one of the manifold downpipes, the slightly modded arb mounts I got aren't modded enough (becasue I'm using a thicker racing dynamics arb with poly mounts) so my brother has taken a set away to weld some extra metal into. Due to getting the front ARB off we had to undo the lolipops to get the arms out of the way and now can't get them back into place and onto the dowels.
I really really want to smash this piece of shit to bits big time and curse myself for starting the whole project and should have just bought a roadworthy 325, but i'm too far in now and her indoors has assured me I am not quitting on it.
Again, working with about 18" of ground clearance on axle stands with about a foot of room either side of the car takes the biscuit.
I tell you what, this shitbox had better be worth it
Post
Mon May 25, 2009 6:05 pm
If you cant get fluid through to the fronts there is a possibility you made the spacer too long, back the M/C nuts off until it runs through. You shouldnt need anybody pressing the pedal, gravity is enough to get the air out
Post
Mon May 25, 2009 6:10 pm
well I have a problem with my brake pedal anyway because it moves a bit, then sticks then frees, and the clunk sounds like it is coming from the servo or the pivot arrangement in the passenger footwell so that could well be my problem.
The porridge wog i got it from has been a stellar example of how to bodge something together, so probably part of his lasting legacy. I shall investigate.
When you say back the m/c nuts off, do you mean where it is bolted to the servo?
Post
Mon May 25, 2009 6:17 pm
Yes, I take it you have made a spacer? If not then thats what the clunking will be
Post
Mon May 25, 2009 6:25 pm
I haven't touched the servo & M/c mate, the clio servo came bolted to an E30 m/c, so I'll have a gander and see if there is any spacer present or not.
Don't forget, this is my plug & play setup mate
The only plug & play part of this cursed adventure so far has been the wiring looms I have bought from you.
Dezzy
Post
Mon May 25, 2009 9:00 pm
Ha ha its dead easy reading the threads on here and thinking its going to be a straight swap isnt it mate. I havent even got the e36 stripped yet. I am in the middle of looking into supercharging and stand alone ecu but dont know where to start with that. Dont know if the plastic inlet manifold will stand up to forced induction, or how to go about fueling it but still fancy 280ish brake. How much you got left lee? Thats something else i dont know wether to mess about with the looms or just to megasquirt it idea ideas. Do you know anyone whos good with this kind of caper up this way mate
Bob_S
Post
Mon May 25, 2009 9:41 pm
it's nearly there lee, my conversion went swimmingly I thought apart from the 2.8 fly and m42 box issue but otherwise didnt really suffer.
It'll be worth it lee just have to keep at it!
Bollocks to this 24v scrap!
E30Gheko
Post
Mon May 25, 2009 10:03 pm
Keep goin fella! I got my lollipops on and then decided to replace the bolts and they were a swine to wrestle back on again! Persevere u'll get there.
robbo86
Post
Tue May 26, 2009 12:57 am
Organise another zone meet to give you another burst of inspiration.
Post
Sat May 30, 2009 3:02 pm
No progress to report, other than more morsels obtained
Courtesy of uncle Jules
E30Gheko
Post
Sat May 30, 2009 3:10 pm
Thought u had oxblood leather?
Daf318is
Post
Sat May 30, 2009 3:37 pm
E30BeemerLad wrote:No progress to report, other than more morsels obtained
You won't be able to go to a quiet road and have a "good time" with your missus with those in it
Look
though!
Now driving an E46 320D touring
, but it get's worse..... the new project is going to be Ford powered!
Post
Sat May 30, 2009 5:28 pm
E30Gheko wrote:Thought u had oxblood leather?
Moved the Oxblood on about 6 months ago, they were for a 4dr so the rear seats won't fit a touring
These with the rear seats dyed black will look acceptable though
E30Gheko
Post
Sat May 30, 2009 11:44 pm
E30BeemerLad wrote:E30Gheko wrote:Thought u had oxblood leather?
After watching this build I think the sparcos are far more apropriate!
bigredbmw
- Zone Supporter
Post
Sun May 31, 2009 9:06 am
looking good lee m8 .............
Dezzy
Post
Sun May 31, 2009 6:10 pm
Nice seats Lee. Will they be comfy enough? When do you think the car will be ready
Post
Sun May 31, 2009 6:13 pm
couple more weeks I reckon
Every time I get going I hit another snag. Today I have discovered I have a non-ABS master cylinder fitted upto the clio servo
So I have a surplus outlet. Got a second hand one sorted.
Got a few silly things done though and will post up some pics later. It's coming together though.
God knows if the seats will be comfy though
aj_mckay
Post
Sun May 31, 2009 6:14 pm
Those seats were a bit of a bargain from Jules in my book. Was VERY tempted myself but no point as I'm selling up in Sept unfortunately
Post
Sun May 31, 2009 6:18 pm
They don't seem bad do they and they have the right mounting frames etc as they were on Colin's V8 touring for a bit.
Had been looking at 4dr Impreza seats but these will do the ticket nicely.
If they are uncomfortable or I don't get on with them I'll always be able to move them on for what I paid for them
aj_mckay
Post
Sun May 31, 2009 6:47 pm
E30BeemerLad wrote:They don't seem bad do they and they have the right mounting frames etc as they were on Colin's V8 touring for a bit.
Very true. No sliders but I guess if you're the only one driving the thing you don't need them! I had also heard that Impreza seats fit nicely. Guess most cars with a transmission tunnel would be potential donors!
Dezzy
Post
Sun May 31, 2009 8:08 pm
I have a cylinder if you need one mate. Just let me know and i will post it down for you. I made a spacer up yesterday for the clio servo. Got that sorted. Friday the 36 is getting stripped so should have some pics. Also got my hands on a ecu module to sort the fueling out for the supercharger. Going for a jag v8 eaton m112. Think that should raise some pulses.
Post
Sun May 31, 2009 9:40 pm
Dezzy, I think you should sell Omi your diff so I can buy his 3.91
Dezzy
Post
Sun May 31, 2009 10:08 pm
He hasnt been back on mate. Was looking at a 3.25 but dont have the money at the mo just to buy one outright just spent it on a charger and ecu.
Omi
- Witty custom rank.
Post
Mon Jun 01, 2009 12:20 am
I'm always on dude, generally have a peek in 3 or 4 times a day, see if there's any entertainment, bargains or if Lee has made any bloody progress... - Just waiting for you to take the leap and spend the extra on the Torsen M-Coupe diff. - Cooler oil and no clutches to wear out!
Might be a consideration if you're rocking Supercharged 24v power, as I don't think the M40 box you mentioned previously will take big power forever. -It's rated at 240NM, the Getrag 240 from the iS (M40 same box?). - Mine's fine N/A but I'm getting a bit of noise off 1st motion shaft. Maybe it's me being paranoid and it was always there?
Lee is sitting on a bundle of £20 notes labelled DIFF. ;) I'm skint, but there's a workable 3-way here.
...or is it?
Post
Mon Jun 01, 2009 8:48 am
You just need to blank that 3rd outlet off Lee, you should be able to get a blank from a motor factors
buster
Post
Mon Jun 01, 2009 2:36 pm
i think a standard bleed nipple will fit the master cyl
Dezzy
Post
Mon Jun 01, 2009 5:28 pm
Omi wrote:I'm always on dude, generally have a peek in 3 or 4 times a day, see if there's any entertainment, bargains or if Lee has made any bloody progress... - Just waiting for you to take the leap and spend the extra on the Torsen M-Coupe diff. - Cooler oil and no clutches to wear out!
I ment to me about the diff not on here mate
I am open to offers but have got a couple of spare boxes and a lighened m20 flywheel and brand new m3 sach cluch so not really bother about it. Would perfer the zf box in but really think that will be down the line at some point now
Post
Mon Jun 01, 2009 6:50 pm
buster wrote:i think a standard bleed nipple will fit the master cyl
I would have thought they were too small, ive used brake unions full of weld before with no problems
buster
Post
Mon Jun 01, 2009 6:52 pm
my audi master cylinder had 2 bleed nipples in it instead of blanks.
Post
Mon Jun 01, 2009 10:21 pm
I checked, the bleed nipples are too small, am going to take the master cylinder to the motor factors tomorrow lunchtime to get an appropriate bolt to put in there.
Bought all the new lightbulbs I need today and a chavy universal cone filter just to get me by for now, I have an M30 air box but can't be fagged playing with that for now.
Hopefully my brother has tacked some extra metal to the front ARB mounts so it lowers the anchoring point for the arb and out of the way of the manifold.
Not far from MOT time now boys
billgatese30
Post
Mon Jun 01, 2009 11:30 pm
may i be the first to say
.... about farking time
I anticipate its release at york
Dominitry
Post
Mon Jun 01, 2009 11:39 pm
When did you get a Supra?!
- **BANNED**
Post
Tue Jun 02, 2009 7:39 am
Bodgers way with the brake master would be a standard pipe fitting with a short length of kunifer with one end plugged with solder....
Youth is wasted on the young.
