M30 Turbo update thread ****RUNNING
jonmsm
Post Sun Jun 18, 2006 3:28 am
VERY VERY cool toby!!
I am very much looking forward to seeing it! I have a 10 ton press if you need to press those son of a b1tch bushes out just up here in Loughborough, I know they are a SOD without a press as I need to do both M535i rear sub frame bushes some times in the next 100 years when I get round to it.
As for the over heating issues... Take a steak and some eggs everywhere with you, next time you get stuck in traffic you can pop the bonnet and sell abit of road side café food! haha.
On a ore serious note, I have a small kenlowe fan that is spare to you if you want it, which you may be able to mount somewhere to give you extra cooling to the rad/IC. Also have alook at the cowlings about the front of the car. A HELL of alot of the effectiveness of the radiator is based on the air being 'channelled' into the rad essentially, as its a high resistance to air flow and so the flow will move around it if there are gaps. This will even be the case if your in traffic and just the fan is running too!! (I have a whole semesters worth of lecture notes on this shite if you wanna have a look see if you can improve your air flow across the rad).
The rubber seal idea is pretty aerodynamically good, as the bottom on the windscreen is a low pressure area due to the acceleration of the air flow vertically to follow the windscreen. The opening of a gap to the low pressre areas should happily drag the higher pressure air coming into the radiator and engine bay back across the engine (cooling everything) and out the back of the bonnet to rejoin the overbody flow.
Look forward to hearing from you soon (should be getting both M535i's ready for re-MOT soon too... but not sure which one to take to the ring as the dogleg it SO much fun with the lower ratios!!!)
P.S. How much are the 850 T5's you wrote about worth... I just got one for free with 180k on the clock and ALOT of new bits :-D
1986 e28 M535i (gone and missed)
1988 e30 320i cab (full resto STILL in progress)
1996 Volvo 850 T-5 estate (280bhp Turbo Nutter), T-5R (my precious)
1966 Fiat 850 saloon & 1970 Sport Coupe
C1 (go-kart)
RowdyBurns
Post Sun Jun 18, 2006 7:26 am
I have found the best way to get sub frame bushes out is to burn the rubber out with oxy/acetaline and then you can tap the housing in on its self and push it out of the beam nice and easy.
May as well replace them with some nice stiff poly items when you do it as all that power/torque will give the stock rubber ones a hard time.
Geeman
Post Sun Jun 18, 2006 11:20 am
Woo hoo!
This car is mental! It's very bloody fast... went out for a quick spin with him down the road and had a permanent grin on my face all the time... and that was only on 5psi... Toby reckons it'll run 11psi... Oh my God!
Just needs to bloody clean it and ditch the tech 2 spoiler! :wink:
Mind you saying that, it'll probably need the spoiler to keep the car on the ground!
Very, very impressed! :cool:
WillG
Post Sun Jun 18, 2006 11:56 am
RowdyBurns wrote:I have found the best way to get sub frame bushes out is to burn the rubber out with oxy/acetaline and then you can tap the housing in on its self and push it out of the beam nice and easy.
Yeah and they still tight then you can weld round the inside of them and that contract the sleeve and then they tap out really easy, I weld piece of metal across aswell to make it easy to beat on. This is how i used to change BV206 torsion bushes and I did it on my GF's AX subframe at home
Ziggy
Post Sun Jun 18, 2006 1:43 pm
It shifts a bit! :eek:
You sure you don't wanna make me a mani toby?!
Andy335Touring
Post Sun Jun 18, 2006 5:29 pm
Sounds like it's going well on Ant's base map :cool:
Toby_Unna
Boost Junkie
Post Mon Jun 19, 2006 3:11 pm
:banana: bushes done in 4 hours this morning
have mot, have tax :D
now it's time to start sorting problems out lol
Andy, i'll try to get up to you in it shortly (if i can afford the fuel :eek: ). Jon, Giles, good to meet up again!
Toby_Unna
Boost Junkie
Post Mon Jun 19, 2006 3:15 pm
and oh yes, while i was waiting for the mot i noticed that (as Gareth said it might be) (cough) the fan is wired in slightly the wrong way round :screwy: :screwy: :screwy: :screwy: :banghead:
anyway i doubt fixing this will sort it completely so i'm off to the scrappy to get a cheap black bonnet i can put a big hole in :rasta:
dan_emaps
Post Mon Jun 19, 2006 3:29 pm
LOL, easily done man, but if your fan had that orange sticker showing the way of rotation then theres no excuses lmao!
I wired mine up the wrong way round to start with on the rallye but you can soon tell when it comes on!
I'd expect it to make a good difference dude, essentially you've been running the car with no fan, but still a bonnet cut out although not the best looking is a good idea
Toby_Unna
Boost Junkie
Post Mon Jun 19, 2006 3:31 pm
it's a second hand Spal, and the wires are black and blue :mad:
the only marking says Made in Italy which says it all really :roll:
Ziggy
Post Mon Jun 19, 2006 4:00 pm
:woohoo: Had a chance to go for a good blast yet??
Good job on the bushes btw! How did you go about it?
Toby_Unna
Boost Junkie
Post Mon Jun 19, 2006 4:44 pm
um yeah seen 130 today lol
was ready for a fight with the bushes but it wasn't that bad. would have been pretty tough without welder and metre long pry bar though :?
Andy335Touring
Post Mon Jun 19, 2006 7:18 pm
Toby_Unna wrote::banana: bushes done in 4 hours this morning
4 hours !!!!
:bow:
I'm looking forward to a ride in the beast already !
Is Ant still comming up to help with the mapping this week ?
Ant
Retired Team Member
Retired Team Member
Post Mon Jun 19, 2006 7:21 pm
Andy/Toby, be up Wednesday earlyish am.
will bring my LM-1 and laptop along, dont forget I need a working fag lighter socket Toby !!!!
gareth
Post Mon Jun 19, 2006 7:52 pm
Toby_Unna wrote:and oh yes, while i was waiting for the mot i noticed that (as Gareth said it might be) (cough) the fan is wired in slightly the wrong way round :screwy: :screwy: :screwy: :screwy: :banghead:
:D :chuckle: :chuckle: :chuckle: :rofl: :teehee: :snigger: :snigger: :notworthy: :tongue: :thumb: :lol:
i can't believe you wired up the whole management right and got the fan backwards!!! :D well, i can believe it as i did too and judging by the comments i've seen, most people do!!!!
was yours ok when sitting stationary? mine was but then overheated as soon as i started moving!
anyway, good news in a way as that's one thing that can easily be changed and will help the heat.
rear beam bushes in 4 hours... just shown what the urge to drive a 3.5 turbo can do to your spannering speed!!! :D :D :D
Toby_Unna
Boost Junkie
Post Mon Jun 19, 2006 7:58 pm
it was the urge of an impending dvla fine if i didn't get the damn thing an MOT sharpish mate!
and yes, regarding fan wiring, i am a class 1 idiot.
doesn't even like sitting still much, but there's a lot of heat to get rid of and an IC to blow through too.
Ant, fag lighter socket :eek: good point better get the multimeter out again
Andy, need to meet up soon mate. u working wed? i can nip over in the pug and collect you, might be heading up notts direction in the evening anyway?
gareth
toby, how does this baby compare to yours?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... B:DS:UK:28
it may be a bit too big still....
edit, i find it quite amusing that the link above includes the code for one of these: :D
:thumb:
Andy335Touring
Post Mon Jun 19, 2006 8:08 pm
I'm on holiday this week mate so i can work it around you, erm it's a bit of long way to come and pick me up though, are you sure ?
terrybpp
Post Mon Jun 19, 2006 8:29 pm
I'm doing a m30 turbo swap over here in the states:
http://www.e30tech.com/forum/viewtopic.php?t=22406
Maybe you can help with a problem I'm having. I can't keep my VR sensor for the EDIS system to not touch the radiator. Do you have any pics of your VR senor/ wheel setup?
gareth
Post Mon Jun 19, 2006 9:10 pm
hi terry, welcome to the 'zone.
i don't have a turbo but do have a M30 in mine. do you want to run the aircon on yours? i have my engine in position 2.5 (most common over here, halfway between position 2 and 3 on the e30.com mounts) but i had to remove the section of pulley wheel (for the aircon) just to get the rad in. yours looks to be about an inch longer than mine ended up so it's going to be tight...
maybe toby will have a solution...
terrybpp
Post Mon Jun 19, 2006 9:51 pm
Mine is in position 2 using the e30.de mounts. Not planning on using A/C but I need room for a BIG intercooler.
I'm thinking about using a Honda radiator that will fit inside the frame. Recess it in an inch. Not sure if a 16" x 20" rad will cool a turbo 3.5 though.
gareth
Post Mon Jun 19, 2006 11:09 pm
i reckon you'll have to go to position 3 at least then... :?
have you got the prop and exhaust done yet?
terrybpp
Post Tue Jun 20, 2006 12:23 pm
My mistake, the positions are 2 & 3 and I am in 3 now. Can't go back any further. I'm using a older m30.
Toby posted on e30tech stating that he used the factory e34 60-2 wheel which is the better solution and a good reason to use the B35.
Anyone know how thick the e28 rad is?
Sorry about highjacking your thread toby.
Geeman
Post Tue Jun 20, 2006 12:33 pm
Toby's using the E28 rad isn't he...?
Andy335Touring
Post Tue Jun 20, 2006 1:38 pm
terrybpp wrote: Toby posted on e30tech stating that he used the factory e34 60-2 wheel which is the better solution and a good reason to use the B35.
The core of the E28 rad is 35mm thick going up to about 50mm thick at the ends excluding the pipe conections.
Do you need a 60-2 wheel ? I've got a spare one.
terrybpp
Post Tue Jun 20, 2006 5:31 pm
Then the e28 is .1" wider than the one I have already. Won't work any better. I'll call Griffin Radiators over here and see what they have.
I'd rather stick with the 36-1. I hear there are still glitches using the 60-1. Thanks though.
Ant
Retired Team Member
Retired Team Member
Post Tue Jun 20, 2006 5:33 pm
I'm of to Toby's tomoz Terry, he is using the 60-2 without issue , as are a few of us, no ned to rero in the 36-1, its lower resoloution for starters M8
I dropped you a PM with a personal request too BTW .
Turbo-Brown
Boost Junkie
Post Tue Jun 20, 2006 9:25 pm
This whole resolution thing was thrown into darkness for me when I read the manual that came with the OMEX I bought for the S50.
It goes on about only sampling the trigger wheel every so often for speed and position and how changing the sampling rate brings different pros and cons.
I'd assumed that the ECU watched the trigger like a hawk and that was that.
Very confusing!
Andy335Touring
Post Wed Jun 21, 2006 7:47 pm
Hows it going now chaps ? 8)
Ant
Retired Team Member
Retired Team Member
Post Wed Jun 21, 2006 7:50 pm
I'm back from my cross country tour.
Toby's car is an impressive beast for sure, the whole project is a credit to ya fella.
Had some mapping fun today, mainly coz my laptop developed a dry joint @ the power inlet and kept shutting down, the basemap I sent Toby was surprisingly good in the top end on boost, needed a fair few tweaks down low and at lower loads, ignition timing was a little retarded in places picked up much better on accel on/off testing with the timing dialled in, much nicer to drive all round IMHO
Idle was excellent, very smooth and we could lean right off to 16:1 AFR without issue, for now she's running stoich with 12 degrees timing, smooth as silk and defo better than stock
Good day, good company, great car.... who's next then ? :cool:
Andy335Touring
Post Wed Jun 21, 2006 7:57 pm
Cool !
What sort of boost is it running now ?
Do you think it's making over the 300bhp/LBS mark ?
Ant
Retired Team Member
Retired Team Member
Post Wed Jun 21, 2006 8:10 pm
Had to leave the boost @ 5.5 psi, the 30# injectors were running 99.7% PWM so an upgrade in base fuel pressure or bigger units are required to move forward.
prolly not far wrong on the 300HP/Lb estimate, sure eats up the highway :twisted:
Andy335Touring
Post Wed Jun 21, 2006 8:14 pm
I bet it does ! :cool:
Turbo-Brown
Boost Junkie
Post Wed Jun 21, 2006 8:15 pm
Wahey!
Go Ant and Toby! :D
With 99% duration on 30lb injectors you should easily be seeing over 300bhp!
With mine going at 97% I'm getting 270bhp and mine are only just over 20lbs/hr!
Toby_Unna
Boost Junkie
Post Wed Jun 21, 2006 10:03 pm
Ant wrote: Good day, good company, great car....
my thoughts exactly mate
thanks for taking the time to get over, pretty productive day as far as i'm concerned... sorry you had to come so far dude! u take a different way back then?
dunno about 300bhp... boost comes i quite progressively so it's deceptive i guess, no massive thump in the back but it does go quite well
Sods law my feckin laptop battery's playing ball again now Ant :x
5.5psi will stay for the time being, need more fuel lol
