m30 probs(no more)
jaffro
tried a new 1 same prob
What are you bridging to get it working? It's possible you may have a blown fuse and even ignition switches sometimes play up. Does the car have an immobiliser fitted?
jaffro
ive just read a thread a i think is because my starter has packed up again so pump wont run unless engine turning which it isnt
Immobiliser on the blink? I notice your cab has that magnetic key lock on the driver's door...
jaffro
immobiliser was took off. il just have 2 wait for new starter a go from there. thanks anyway
No worries, good luck
jaffro
i definatly need it lolSpeedtouch wrote:No worries, good luck
Templ8e30
The fuel pump will run when the relay socket is bridged, even with the ignition off, that's normal.
Try giving the starter motor solenoid a sharp tap, the solenoid is probably sticking.
I bet the starter is a bitch to get at now it's in the car
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Chris-W
jaffro
cheers chris i got huge smile on my face again now.
jaffro
the cab will be up for sale soon so if any1 has any tech 2 rear bumpers fiberglass is ok a bits im willing to swap for the nitrous wet kit thats also in the for sale section
jaffro
got my exhaust on and now there seems 2 be a knocking on bottom end of the engine that goes away when warmed up anybody any ideas ?? also need another rad now
