no heat from the heater at all,
got the e34 header fitted to the bulkhead area without it hitting the bonnet,its close but not hitting,it looks well up there if i could get the thing bled,the front off the engine sits slightly higher than the rad ,this the way they all sit?changed the rad to a e36 325tds rad out off a car i had broke ,its a lot bigger but still no difference.
335i cooling problem.
alan335i
89 335i sport
alan335i
fitted a fan from a hdi xsara,its blowing the right way ok,its big enough, it fills the complete space at the front.Yaninnya wrote:Maybe a dumb question but do you have electric fan? If yes how big it is (is it blowing in the right direction?) and did you checked the fan swich?
Jan
89 335i sport
SPADGE
The only thing i can think of now is the heater valve or the matrix itself!
Maybe it isn't opening and allowing the coolant to circulate or the matrix is blocked?
Perhaps you could try bypassing the heater matrix by joining the 2 pipes that go to it and see if that makes a difference?
Yaninnya
To the back of the car?alan335i wrote:its blowing the right way ok
Also I think that this double s shape hose to heater shoud be very suspected. Try to change it to something more strait.
Basically there no magic in any cooling system (and specially in E30 generation cars) so it must be something quite simple.
Just my 2p.
Jan
alan335i
[quote]
yes its pulling the air in towards the engine.
89 335i sport
