m60 swap ( UPDATE 29.04.07)
Post Mon Oct 16, 2006 11:38 pm
Demlotcrew wrote:Well you will be shocked to know that
it weighs more than a M30 and we know
how much that affects the handling in a E30.
Andrew
According to this site, the unbuilt M60 weighs a whole 3kg more than an M30 :roll:
Im sure that if his interest was to go screaming round a track he wouldnt have even considered doing this conversion either
bigdek
Post Mon Oct 16, 2006 11:39 pm
not with an auto anyway :eek:
Post Mon Oct 16, 2006 11:42 pm
I think what andrew is trying to say is
"my cars better than yours, ner ner ne ner neer" :P
Yaninnya
Post Mon Oct 16, 2006 11:48 pm
Demlotcrew wrote:From BMW technical manuals.
Andrew
And where in TIS you found it? :roll:
Jan
Andy325i
Post Tue Oct 17, 2006 12:25 am
Total respect :D There is no replacement for displacement :D Keep us posted
Andy
DaleR
Post Tue Oct 17, 2006 1:10 am
Nice work mate :), any nikasil issues with that block?.
Demlotcrew
Post Tue Oct 17, 2006 9:06 am
Well i get 134kg for the M30
And 154kg for the M60
And 110kg for the S14
And 103kg for the M42
All are dry and totaly bare with just block head and sump/timing covers etc.
Andrew
Demlotcrew
Post Tue Oct 17, 2006 9:17 am
DanThe wrote:I think what andrew is trying to say is
Far from it,
Ive not seen this lads car so i cant comment!
Im just trying to make things transparent so
people can read past all the internet (Maxfield type) bullshit!
Ive had the opportunity to drive and work on many E30 conversions
so i feel like i have good grounds on which i can comment.
You guys can carry on dreaming about 215bhp M50's and lighter than
life V8 blocks.
But ive worked on â┚¬Ã‹Å“properâ┚¬Ã¢”ž¢ M6X conversions and i know quite a bit
about them.
Im only trying to help, but ill refrain from doing so from now on. :D
Andrew
Toby_Unna
Boost Junkie
Post Tue Oct 17, 2006 9:37 am
Demlotcrew wrote:Well i get 134kg for the M30
Andrew
do your books not have fully dressed weights then?
I'm not going to pretend to know (because I don't) - but I wouldn't be particularly surprised if the M60 was equipped with significantly lighter ancillaries. have you felt the weight of an 535i alternator andrew? :eek:
Demlotcrew wrote: Well you will be shocked to know that
Andrew
cool, whose M30 car did you drive then, did it go well?
Demlotcrew
Post Tue Oct 17, 2006 10:51 am
Toby it was an alpina B6 which has good suspension fitted with bigger brakes.
M60 Alternator 7.5kg
M30 alternator 7.16kg
Both are 140A
Andrew
m-dtech
Unapproved Trader caution
Post Tue Oct 17, 2006 11:04 am
looking good, bit of extra weight upfront aint a bad thing if you wanna drift :D
Toby_Unna
Boost Junkie
Post Tue Oct 17, 2006 12:07 pm
fair enough, did the b6 not handle very well then?
what's a bare m20 weigh according to your books?
do you not know how much the m20/30/60 weigh ready-to-go?
sorry for going O/T Derek. :(
e30bemer
Nutters
Nutters
Post Tue Oct 17, 2006 12:14 pm
thats gonna be awesome!
proper street sleeper!
Post Tue Oct 17, 2006 4:56 pm
Demlotcrew wrote:Im only trying to help, but ill refrain from doing so from now on. :D
Your not trying to help, your trying to be clever.
And from what ive read elsewhere it seems all you want to do is get reactions from people by adding snide comments to their threads
maxfield
Post Tue Oct 17, 2006 5:08 pm
Demlot what is your problem with me??
Post Tue Oct 17, 2006 5:51 pm
He seems to have a problem with a few Maxfield, and I dont know why :?
According to him ive dreamt my M50 conversion :roll:
maxfield
Post Tue Oct 17, 2006 5:56 pm
You probably did... but then you put that dream into a reality :D
Taxin
Post Tue Oct 17, 2006 6:12 pm
Hi you might consider using these for extra space
you can buy them at www.300mm.de EUR 99
Detailed pics of the conversion can be found here itâ┚¬Ã¢”ž¢s in German but the pics might help if you get stuck for ideas I can translate if you get stuck
http://wp1016621.wp027.webpack.hosteuro ... f01459.htm
BMW E30 Convertible - 2.5
bigdek
Post Tue Oct 17, 2006 6:16 pm
spacers not reqd and i dont like that idea personally.
Think i may have just purchased a manual box, clutch , flywheel and clutch cylindwe for the bargain price of Ԛ£150
Post Tue Oct 17, 2006 6:19 pm
You jammy git :D
jonbuoy
Post Tue Oct 17, 2006 6:42 pm
This is a great project dude, going well so far winkeye
Don't know if this will work but was talking to a mate the other day who build's performance car's for a living and he's going to do this conversion on a customer's car and is under the impression that the M3 manual box from the E36 will fit using the the bell housing shroud from the auto box originally attached to the V12.
I did'nt believe his belief this will work as i'm sure if it's as easy as that then Glenn may have gone down that road with Dips' car :?
What are your view's? Would it work?
Yaninnya
You are taking the weights from ETK not from TIS. Weights in ETK are overall (with pallet, box, securing tapes, etc). It means that if one of these engines is packed in different way (and it usually is when engine is made in different factory) this weight is not adequate at all.
Jan
Post Tue Oct 17, 2006 6:54 pm
Another thing, I reckon an M30's manifolds weigh more than an M60's, M30 has that big ally inlet lump compared to the M60's plastic
jmc330i
Post Tue Oct 17, 2006 7:01 pm
jonbuoy wrote:Don't know if this will work but was talking to a mate the other day who build's performance car's for a living and he's going to do this conversion on a customer's car and is under the impression that the M3 manual box from the E36 will fit using the the bell housing shroud from the auto box originally attached to the V12.
Im not sure about the E36 M3 6spd box, but the E36 M3 5spd box does not have a detachable bell housing so I dont think that would work.
James
'91 325i Sport
'93 318i touring 16v
bigdek
Post Tue Oct 17, 2006 7:06 pm
i think its the same box but slightly different ratios.
However i dont think the v12 bolt pattern on the bellhousing is the same as the v8.
i had a look through Glenns v12 swap post and it doesn't look the same.
Demlotcrew
Post Tue Oct 17, 2006 7:12 pm
Jan
Oh so the pallet and straps etc for the S14 weight only 6kg!
They must use carbon fiber.
winkeye
glenn
Engine Transplant Services
Post Tue Oct 17, 2006 7:54 pm
that's a good find derek!
the bolt pattern's for the V8 and V12, are different
buster
Post Wed Oct 18, 2006 9:46 am
nice conversion bud ! It'll sound awesome :twisted:
Yaninnya
Post Wed Oct 18, 2006 7:08 pm
Demlotcrew wrote:Oh so the pallet and straps etc for the S14 weight only 6kg! They must use carbon fiber.
Could you explain what you are trying to say? I'm trying but I can't guess.
Jan
gareth
Post Wed Oct 18, 2006 8:53 pm
i seem to remember recently helping out a fellow zoner as you tried to above, only to recieve a load of cr4p from you as you seem to disbelieve anything i have to say.
i take it in this instance you have the definitive knowledge / info with which to correctly answer a question that other zoners are speculating over and thought that sharing that information would be well greeted?
glass houses mate. winkeye
regarding engine weights, there are other factors to consider. a 'V' engine has a higher centre of gravity as more of it's mass is distributed higher up (two heads, not one). there are also two exhaust manifolds and a heavier exhasut system to consider.
the best way to get a good idea of conversion weights is to get on a weigh bridge (srapyards often have them) before and after doing the conversion. i wish i had as this would be interesting... :? next time then! :D
incidentally, the M30 conversion does feel heavier in my touring but as i started with a already heavy M20 touring, the difference was not so pronounced. a conversion from a 4 pot 2 door would feel a lot heavier as the percentage increase in the cars weight would be greater.
bigdek
Post Wed Oct 18, 2006 8:58 pm
Obviously the springs and shocks will be changed to suit the extra weight.
probably custom springs though as i had h & r on my touring and they were ok but i feel they could be improved on
At a bit of a stand still just now as my manual box is coming next week ( woohoo).
will be sorting the brake servo out this weekend and will make a start on the headers i think.
gareth
Post Wed Oct 18, 2006 9:11 pm
bigdek wrote:my manual box is coming next week ( woohoo).
result! :D
did it set you back much?
bigdek
Post Wed Oct 18, 2006 9:38 pm
LOL .
Bargain of the century.
Clutch, flywheel, gearbox , clutch slave cylinder
Ԛ£150 notes .
being delivered next week
Andy325i
Post Wed Oct 18, 2006 9:54 pm
Nice :D What box is it you are using?
Andy
bigdek
Post Wed Oct 18, 2006 10:03 pm
5 spd from 530 v8
